Login problem after upgrade from 10.3.1 to 10.4.4
MariusMiclea
Hello,
I upgrade Plesk for windows form 10.3.1 to 10.4.4 from plesk Panel. Everything worked fine. After i restart the server and try to login with my admin password i get this error:
"Error: Unable to log you on. An internal error occurred in the Single Sign-on authorization engine. Please try logging in later, and contact your hosting service provider if the problem persists. "
I check with other users (not admin user) and i get the same error for all the users.
I searched for a solution but i could not find one.
Any ideas? Thanks
Marius
[Solved]
The problem was on the Server Settings >> Full hostname , it was changed six months ago after plesk installation.
In the file Plesk/admin/conf/sso/sso_config.ini , hostname in the file was with the old name (instalation hostname). After i edit with the new hostname everything worked fine, and i'm happy :).
Marius
