Wahaib1981
Hi there,
I have the following setup Fresh installed on 2013-10-28:
Windows 2008 Enterprise SP2
Plesk Panel 10.4.4
Mail-enable Enterprise mail server with Webmail Client 2.0
As every one Know Plesk comes with Mail-enable as mail server and Horde as webmail as pre set, after that we have upgraded Mail-Server to Enterprise Ver 7.X ( Though it is not on the tested list of Plesk but it have worked fine with me due to some other errors we had to re-install the server ).
Mails are working fine and relaying incoming / out going , mail quota settings in side plesk all works fine. and accessible as well on http://webmail.webdreamsjp.com Or webmail.domain.com
Problem:
Setting up mail-enable as Default Webmail Client for the domains having problem when accessing the webmail from inside the Plesk panel going to domain>> Control-panel>> Mail Section clocking on >> More>> clicking on mail Preview>> it though ERROR 404, i have tried Mail-enable Forum and also Plesk KB but no Luck. ( Plesk KB was a very old post though before 10.4.4). Than i have hired the Professionals to help too and the came up with following message:
"As discussed over the Skype chat, We have discussed on the issues with "mewebmail" client redirection when previewed from plesk panel and how the custom redirection scripts placed by us enables the same redirection feature over web browser as per your requirement. As informed you over the chat the scenario is the same as explained in the Mailenable forum "http://forum.mailenable.com/viewtopic.php?f=3&t=23106", webmail.domain.xx instead of domain.xx/mewebmail" that confirms the problem is with the Plesk panel which does not allow the redirection for the MailEnable web mail interface correctly when you have set the MailEnable web mail as the default web mail client. As you have informed us that you would get in touch with Parallels support regarding this issue after all is done as per your requirement, We will continue to work on other requirements that are pending. We will keep you updated on the progress.
http://forum.mailenable.com/viewtopic.php?f=3&t=23106#p80763
Re: webmail.domain.xx instead of domain.xx/mewebmail
Postby MailEnable-Ian » Mon Dec 12, 2011 3:21 am "
IF any one !! Any one at all can help i will really appreciate.
Plesk Panel 10.4.4
Problem:
