• Dear Pleskians! The Plesk Forum will be undergoing scheduled maintenance on Monday, 7th of July, at 9:00 AM UTC. The expected maintenance window is 2 hours.
    Thank you in advance for your patience and understanding on the matter.
Mailman delivery problem
W
WebDev90
I am a new user here and this is the first time that I use mailman as mailing list solution.
I have a dedicated server on a German ISP (Strato) and mailman was preinstalled on my system.
I just made settings for users and status of service as described below.
- I have Plesk 7.5 on a Suse 9.3
- Mailman was activated direct on Plesk interface. I do not installed anything manulaly.
- When I create a list, list owner gets a notification msg.
- When I add a user, this new user gets welcome msg.
- Users would login direct web interface for mailman and can do any action direct there.
- BUT when a user sends a msg to the list THERE IS NOT MSG DELIVERED TO THE LIST.
- There is also no information list admin for any action.
Is that a configuration problem, or general what is the problem and what can I do now?
TIA!
Cenk Eder
Migrating
I'm almost similar. I was on an older version of Plesk, and needed to migrate the lists to the new version.
I installed Mailman with the plesk updater.
I created the list in the control panel then copied the filed from the list directory to the new server. Everything appeared to be working properly, since I am able to see all the users, and add/remove users with no problems.
However, list not working.
Creating another list using the control panel and sending out a test email failed as well. So it's not just the lists that I'm trying to "migrate".
Has anyone talked to SWsoft regarding this issues - I mean what's the meaning using a control panel if you have to browse a kb and correct errors that has been known for MONTHS (years?)???
Would you buy a car with as many bugs as Plesk have? Don't think so. If there's a problem with your car that was there when you bought it (brand new), do they charge 100USD/h to fix it? Don't think so...
SWsoft: Please fix issues like this without having users to spend hours fixing it by ourselves. 5000 customers having this problem = 5000+ hours to fix the problem. Time is money - even for customers who buy the control panel. :rolleyes:
