I am trying to migrate the data from one Plesk 8.6 server to a new Plesk 9.5 server.
I dumped all the configuration on the old server with this command :
./PleskX.pl --dump-all --configuration-only
as per the KB article : http://kb.odin.com/en/1152
Everything was fine, then I transferred all the configuration data as stated, onto the new server and tried to restore the data via the GUI panel.
No error message, but no data/configuration was restored, and I get the following message in the migration.log file :
Can you let me know what this means and where .discovered is supposed to be ? Is this a bug, is there a workaround ?
I have another 6 hours to complete this migration, any help would be appreciated.
Thank you
Fred
[00:53:40 - INFO: 2839 p.log] pmm-ras started : /usr/local/psa/admin/bin/pmm-ras --get-dump-list --type=server --guid=727233e0-d2c2-4ae9-9661-40389d8cce85 --id=1 --name=server --session-path=/usr/local/psa/PMM/logs
[00:53:40 - INFO: 2839 p.log] Repository '/var/lib/psa/dumps' initialising...
[00:53:40 - INFO: 2839 p.log] Repository '/var/lib/psa/dumps': Initialized
[00:53:40 - INFO: 2839 p.log] Repository '/var/lib/psa/dumps': List backups of type server for guid 727233e0-d2c2-4ae9-9661-40389d8cce85
[00:53:40 - INFO: 2839 p.log] Get discovered names
[00:53:40 - INFO: 2839 p.log] Search object dirs
[00:53:40 - INFO: 2839 p.log] '.discovered' directory for 'server' '727233e0-d2c2-4ae9-9661-40389d8cce85' not found
[00:53:40 - INFO: 2839 p.log] pmm-ras finished. Exit code: 0
Thank you
Fred
