Question MOUNT Problem
TalkBuildHost
Basic Pleskian
ubuntu latest
latest
Plesk panel and websites are down because the filesystem corruption we discovered has now broken critical Plesk paths, including:
  • /opt/psa/admin/sbin
  • Plesk binaries
  • PHP handlers
  • Webserver configs
This is expected when the filesystem is damaged and not yet repaired.
The good news:Your data is almost certainly still intact. But the server will NOT come back online until /dev/md0p2 is repaired with fsck.
Right now you are stuck in a loop:
  • You think you're in recovery mode
  • But /dev/md0p2 is STILL mounted
  • So fsck refuses to run
  • So the corruption remains
  • So Plesk cannot start
  • So all websites are down
We must fix the root cause:You are NOT in a real rescue environment yet.
  • Plesk binaries
  • PHP handlers
  • Webserver configs
I don't know what you're asking about for this one. It looks like all you did was copy and pasted something that was showing? If need be, using your VPS provider, boot to recovery then use the console to run a fsck on /dev/md0p2.
is this a good way to install plesk?
If you want a default installation then sure that will work.
It was a nightmare trust me i had to go into the actual boot recovery i ask chat gpt the problem they said exact thing but only to not see my whole server network was not network setup properly.
