MS SQL servers are not visible in Parallels Plesk Panel
Ricard Ghigliazza
I have the problem described here: http://kb.odin.com/en/121927
But my Plesk's license allows to use MS SQL Servers.
This began to happen after upgrading Plesk 11 to 12.
In psa Database, in DatabaseServers table it appears. If I delete and add back into Plesk, it shows me no error, but neither added to the database servers.
Thanks for your help.
Is your database on the same server or a different server ?
I was told that plesk 12 does not support remote SQL servers. for that you need "plesk automation."
We have an older remote SQL (2000) database i have not been able to get working so far.
Please I need help with this !
I attach a picture below where you can see the license management section, components and Database servers respectively.
When I try to re add the MSSQL server, the panel tells me that already exists.
