Multiple MAPS entry problem
P
psifx
Just upgraded to 8.0.1
I used to use multiple MAPS, i.e. relays.ordb.org;sbl-xbl.spamhaus.org;cbl.abuseeat.org - and this worked fine.
Now all I can have is relays.ordb.org..... If I put anything else in, when sending email (i.e. SMTP, not webmail) it will not accept email.
The smtp_psa file is formatted correctly, i.e.
-r relays.ordb.org -r sbl-xbl.spamhaus.org -r cbl.abuseeat.org
What gives?
Yes we have been having the same issue is there any progress on this?
It was because the DNS lookup wasn't returning anything.
Paul.
