mysql java connection problem using plesk
R
ramesh
Hi all,
I am trying to move my java web application into new hosting area.
I have uploaded the .war file using plesk 7.5.4, which uses database connection of the same machine.
The database 'test_db' has been created in new hosting area using 'phpmyadmin' web tool of PLESK, the details are,
1. 'test_db' - database name
2. 'tester' - user name
3. 'setpass' - password
The DBConnection of my java application details are,
theConnection = DriverManager.getConnection( "jdbc:mysql://99.99.99.99:3306/test_db?user=tester&password=setpass" );
When evey my application try to talk with my data 'test_db' database, I am getting the following error message.
http://domainname:9080/application/...n:?code=1003&exception=java.sql.SQLException: [^] Unable to connect to any hosts due to exception: java.net.SocketException: java.security.AccessControlException: access denied (java.net.SocketPermission 99.99.99.99:3306 connect,resolve).
Upon researching this, I came to know that, 'test_db' database user 'tester' does not has the access privilege to talk with database.
At this case, I tried to run the following script for authentication.
GRANT ALL PRIVILEGES ON test_db.* to tester@'%' IDENTIFIED by 'setpass';
Or, the hosting plople only has to run the above command. or please make sure, am I going in wrong direction.
plesse help me!
Thank you,
Ramesh
