need help moving cgi-bin
M
micah
Let me start by saying I am not a perl guy or a plesk guy, I just got this job dropped in my lap. I am however familiar with linux. Also, I'm going to try and give as much info as I can, even if its more than you need(want) to know.
Basicly I need to move the cgi-bin to httpdocs/cgi-bin, because of how our webdeveloper developed the scripts.
i've uncommented "AddHandler cgi-script .cgi" in the httpd.conf and restarted httpd. However after doing this, scripts that work perfectly in the cgi-bin in the original location fail when I move them to the new location. the error i get is
Software error:
Can't locate ../lib/blib.pl in @INC (@INC contains: /usr/lib/perl5/5.8.5/i386-linux-thread-multi /usr/lib/perl5/5.8.5 /usr/lib/perl5/site_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.4/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.2/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.1/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.5 /usr/lib/perl5/site_perl/5.8.4 /usr/lib/perl5/site_perl/5.8.3 /usr/lib/perl5/site_perl/5.8.2 /usr/lib/perl5/site_perl/5.8.1 /usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.4/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.3/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.2/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.1/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.5 /usr/lib/perl5/vendor_perl/5.8.4 /usr/lib/perl5/vendor_perl/5.8.3 /usr/lib/perl5/vendor_perl/5.8.2 /usr/lib/perl5/vendor_perl/5.8.1 /usr/lib/perl5/vendor_perl/5.8.0 /usr/lib/perl5/vendor_perl . /etc/httpd/ /etc/httpd/lib/perl) at /var/www/vhosts/domain.org/subdomains/do/httpdocs/cgibin/doAdmin/index.pl line 3.
the code I am running is this
Code:
# head index.pl
#!/usr/bin/perl
require "../lib/blib.pl";
require "../lib/uploadlib.pl";
require "../lib/dolib.pl";
require "../lib/printFadeSlideshow.pl";
use CGI;
use CGI::Carp qw(fatalsToBrowser);
permisions are
Code:
# ll index.pl
-rwxr-xr-x  1 iwsadmin psacln 5316 Mar 22 08:24 index.pl
# ll ../lib/blib.pl
-rwxr-xr-x  1 iwsadmin psacln 68201 Mar 21 14:23 ../lib/blib.pl
oh, and im running RHE 4 and plesk 7.5 reloaded.
And also, this happens to be a subdomain at the moment, but it will move to a normal domain later. If i can do it server wide would be great too.
(also running the script from the command line as root works perfectly, ie. # perl index.pl)
Thanks in advance for any help, even if it ends up pointing to something that may be staring right at me.
