Need help... No SP with id and more problems
Status
Not open for further replies.
SergioMV
First, sorry for my English.
My server with CentOs is starting to problems with installing Plesk 11.
By going to access the control panel, showing me the following error:
No SP with id=andwkce5hx0z6lf37cvv9eewydqbjx3ily2
I found a solution to this in a forum of this site:
http://kb.parallels.com/en/117736
but when trying to launch the command:
/usr/share/plesk-billing/integration --command=repair-all
returns me the following error:
PHP Warning: require_once(/opt/plesk-billing/lib/../thirdparty-libs/symfony2/src/Symfony/Component/ClassLoader/UniversalClassLoader.php): failed to open stream: No such file or directory in /opt/plesk-billing/lib/lib-tk/include/include.php on line 26
PHP Fatal error: require_once(): Failed opening required '/opt/plesk-billing/lib/../thirdparty-libs/symfony2/src/Symfony/Component/ClassLoader/UniversalClassLoader.php' (include_path='/opt/plesk-billing/lib/billing-libs:/opt/plesk-billing/lib/lib-tk/include/pear:/opt/plesk-billing/lib:/usr/local/psa/admin/plib:/usr/local/psa/admin/javascripts:/usr/local/psa/admin/plib/locales:/usr/local/psa/admin/auto_prepend:/usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin:/usr/local/psa/admin/htdocs/domains/databases/phpPgAdmin:/usr/local/psa/admin/smb:/usr/local/psa/admin/smb/application/library:/usr/local/psa/admin/plib/pear:/usr/local/psa/admin/compat') in /opt/plesk-billing/lib/lib-tk/include/include.php on line 26
What do I do?
Have you successfully completed upgrade with
# /usr/local/psa/admin/bin/autoinstaller --select-release-current --upgrade-installed-components
? Have you tried bootstrapper repair procedure?
Yes, this command has finished correctly.
As i do the bootstrapper repair procedure?
Mi domains work correctly, only not working the control panel.
Status
