Resolved no login after manual fix of corrupt installation
TauTau
I somehow had a corrupted half-update from version 12 to the current 17.5.3. I manged to fix it so far with apt-get -f, did a "plesk repair all". I still have an error with DNS:
The NS configuration file '/var/named/run-root/etc/named.conf' is
absent ............................................................ [ERROR]
Restore the DNS configuration file from '/var/named/run-root/etc/named.conf.default'? [Y/n] Y
Restoring the DNS configuration file
'/var/named/run-root/etc/named.conf' ............................ [2017-07-19 21:35:29] ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/filemng' 'root' 'cp' '-r' '/var/named/run-root/etc/named.conf.default' '/var/named/run-root/etc/named.conf' '--allow-root'] with exit code [1]
[FAILED]
- filemng failed: filemng: Error occurred during /bin/cp command.
probably because I have no /var/named/ directory to begin with... Also I can't login currently:
Internal error:
Unable to calculate firewall rule priority with direction '2' for configuration '2'
Message Unable to calculate firewall rule priority with direction '2' for configuration '2'
File FwConfigurator.php
Line 304
Type PleskFatalException
Any ideas what to fix? This is on Ubuntu 14.04 LTS
ok, all is good... the fix with apt-get -f wan't enough, after I ran a plesk install from commandline, it installed a lot of missing stuff, and works again ;)
