Resolved no nginx settings on domain view - please help :)
ink169
Ubuntu 24.04.3
18.0.74 Update #3
Hello!
i have a subdomain which was working on an app on port 3000 just fine
now i have added another one and went to the 'Apache & nginx' setings but there are no nginx options..
How can i verify that nginx is running please
I tried running nginxmgr --status
from the local/psa/admin/bin/folder but it responded 'command not found'
tho i am logged as root
Thanks a lot!
Andy ink
Hello, @ink169 . You can verify whether Nginx is running from the Plesk GUI Tools & Settings > Services Management or via the command line:
Code:
systemctl status nginx
If for some reason the Nginx component is missing, you should be able to add it from Tools & Settings > Updates.
Code:
Thanks a lot Sebahat!
i found where to start the service in the Plesk interface
