• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
OTRS and Plesk: Webserver does not start with vhosts.conf
MarcoJ
i did a manual install of OTRS on a subdomain in my Plesk 10. I've got stuck at the point of configuring Apache for this subdomain, as the OTRS configuration file put in as vhosts.conf will cause the Plesk-Apache not to start anymore.
I would be happy if anybody has an idea on this, i'll attach the vhosts.conf below.
Thanks,
Marco
# added for OTRS (http://otrs.org/)
# $Id: apache2-httpd.include.conf,v 1.18.2.3 2011/04/19 22:09:24 en Exp $
# agent, admin and customer frontend
ScriptAlias /otrs/ "/var/www/vhosts/mydomain.de/support/opt/otrs/bin/cgi-bin/"
Alias /otrs-web/ "/var/www/vhosts/mydomain.de/support/opt/otrs/var/httpd/htdocs/"
# activate this if you are using an Oracle database
#SetEnv ORACLE_HOME /path/to/your/oracle/
#SetEnv ORACLE_SID YOUR_SID
#SetEnv NLS_LANG AMERICAN_AMERICA.UTF8
#SetEnv NLS_DATE_FORMAT 'YYYY-MM-DD HH24:MI:SS'
# if mod_perl is used
<IfModule mod_perl.c>
# load all otrs modules
Perlrequire /var/www/vhosts/mydomain.de/support/opt/otrs/scripts/apache2-perl-startup.pl
# Apache::Reload - Reload Perl Modules when Changed on Disk
PerlModule Apache2::Reload
PerlInitHandler Apache2::Reload
PerlModule Apache2::RequestRec
# set mod_perl2 options
<Location /otrs>
# ErrorDocument 403 /otrs/customer.pl
ErrorDocument 403 /otrs/index.pl
SetHandler perl-script
PerlResponseHandler ModPerl::Registry
Options +ExecCGI
PerlOptions +ParseHeaders
PerlOptions +SetupEnv
Order allow,deny
Allow from all
</Location>
</IfModule>
# directory settings
<Directory "/var/www/vhosts/mydomain.de/support/opt/otrs/bin/cgi-bin/">
AllowOverride None
Options +ExecCGI -Includes
Order allow,deny
Allow from all
</Directory>
<Directory "/var/www/vhosts/mydomain.de/support/opt/otrs/var/httpd/htdocs/">
AllowOverride None
Order allow,deny
Allow from all
</Directory>
<IfModule mod_headers.c>
<Directory "/var/www/vhosts/mydomain.de/support/opt/otrs/var/httpd/htdocs/skins/*/*/css-cache">
<FilesMatch "\.(css|CSS)$">
Header set Cache-Control "max-age=2592000 must-revalidate"
</FilesMatch>
</Directory>
<Directory "/var/www/vhosts/mydomain.de/support/opt/otrs/var/httpd/htdocs/js/js-cache">
<FilesMatch "\.(js|JS)$">
</FilesMatch>
</Directory>
</IfModule>
# MaxRequestsPerChild (so no apache child will be to big!)
Take a look in the apache log to see what, exactly is causing the problem. It should specify the exact nature of the problem if we are lucky.
