Forwarded to devs Paragraph "Restricting Script Execution in the /tmp Directory" is missing in the "Advanced Administration Guide, Plesk for Linux Obsidian" guide
Maarten
Golden Pleskian
Plesk Guru
Username:
TITLE
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
not applicable
PROBLEM DESCRIPTION
In the "Advanced Administration Guide, Plesk for Linux 12.5, there is a paragraph that explains how to secure the /tmp directory:
As this is still a security risk, I wonder why this is missing in the latest Obsidian guide:
Enhancing Security
STEPS TO REPRODUCE
not applicable
ACTUAL RESULT
not applicable
EXPECTED RESULT
not applicable
ANY ADDITIONAL INFORMATION
(DID NOT ANSWER QUESTION)
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM
Answer the question
Consulted with the Plesk Security team. This section is absent because it is not related to Plesk but instead to OS itself. Securing the /tmp directory is not required in the current Plesk security model. Securing this directory may differ for various OSes. It is ok to secure /tmp directory, you could use OS-related instructions outside for securing the server. For example Securing /tmp on a linux server - ITsyndicate
Can you please share more details on the "current Plesk security model"?
Why is securing the /tmp folder no longer needed? Because of SELinux?
It is not "no longer needed". It is just "not needed". Nothing has changed.
  1. The lack of restricting execution in /tmp is not a vulnerability by itself.
  2. Restricting execution in /tmp can make exploitation of some potential vulnerabilities more difficult because this is a well-known location which exploits often try to use.
  3. Restricting execution in /tmp cannot fully protect from such potential vulnerabilities because (almost) always there are directories other than /tmp allowing an exploit to write and execute files.
