permitions problems
brinsleyparagao
Regular Pleskian
I found some problems...
1. if i install dropbox module, i receive minute per minute a email.
2. i cant remove and personalize any error_doc
I try using admin to delete and edit the error_doc, without success :(
About dropbox, impossible using for this error
So how to fix this?
its is a new server, formated and instaled the last plesk version
windows 2012 r2
plesk 12 v18
Hello,
Issue 1 :please check if any schedule task is running in tools and settings section.
Issue 2: - Please check if error_doc folder has correct permission, users like psadm, pscyln, psasrv has correct permissions on it.
About:
Issue 1: it normal now
Issue 2:
Always i need set manualy in any accot when created or modified. irts possible resolve to fix forever?
