Please help: problem after update 8.1.1.
V
viktorf
I have updated my server from 8.1.0 to 8.1.1.
The update has obviously failed because it still shows me the option to update to 8.1.1. If I retry it shows an error:
ERROR: PleskFatalException
Undefined release.
0: /usr/local/psa/admin/plib/common_func.php3:151
psaerror(string 'Undefined release.')
1: /usr/local/psa/admin/htdocs/server/autoinstaller_install.php:16
Allthough all domains van be reached e-mail is not being received.
If I try to manage a domain it fails and shows:
ERROR: PleskMainDBException Add To FavoritesAdd To Favorites
MySQL query failed: Unknown column 'miva' in 'field list'
0: /usr/local/psa/admin/plib/common_func.php3:211
db_query(string 'select `dom_id`,`sys_user_id`,`ip_address_id`,`ssl`,`same_ssl`,`fp`,`fp_ssl`,`fp_enable`,`fp_adm`,`fp_pass`,`ssi`,`php`,`php_safe_mode`,`cgi`,`perl`,`python`,`fastcgi`,`miva`,`coldfusion`,`asp`,`asp_dot_net`,`webstat`,`at_domains` from hosting where `dom_id`=21')
1: /usr/local/psa/admin/plib/class.Table.php:180
Table->select()
2: /usr/local/psa/admin/plib/class.cObject.php:443
cObject->fetchAttrsFromTable_()
3: /usr/local/psa/admin/plib/class.PHosting.php:69
PHosting->PHosting(string '21')
4: /usr/local/psa/admin/plib/common_func.php3:2826
objectMaker(string 'PHosting', string '21')
5: /usr/local/psa/admin/plib/class.DomainControlForm.php:140
DomainControlForm->assign(object of type BsDomain)
6: /usr/local/psa/admin/htdocs/domains/dom_ctrl.php3:152
Does anybody have a solution... i'm quite desperate.
It seems your database upgrade has failed.
You might unpack the distribution archieves and look for the mysql database upgrade files and try running them manually on the database.
