Plesk 11.0.9 MU#28 Application Catalog Problem
JackHosting
Hello Guys,
I have a problem in plesk 11 application catalog. Every time I try to install any web application ex. wordpress, joomla it produce an error like this:
"Error: Unable to install the app because its installation requirements are not met. Contact your hosting provider to resolve this problem."
PHP limits The PHP memory limit is 0 bytes. The app requires at least 40M bytes.
PHP extension The 'mysql' extension was not found.
It seems that plesk can't recognize my installed php extension. FYI I already checked the php.ini everything is set php extensions, mod_rewrite is disabled but still can't fix this problem....
Any help? please.... sorry for bad english...:)
Parallel Plesk 11 user
Do you really have PHP support enabled for this subscription? Any custom .htaccess files there?
