J
jackde
when i try lastest patch of plesk (2007 Feb 06) it's alter some error following
===> psa-8.1.0 depends on file: /usr/local/psa/admin/htdocs/locales/en-US/license.html - not found
===> Verifying reinstall for /usr/local/psa/admin/htdocs/locales/en-US/license.html in /usr/ports/swsoft/psa-locale-base
===> Deinstalling for swsoft/psa-locale-base
===> psa-locale-base not installed, skipping
===> Vulnerability check disabled, database not found
===> Extracting for psa-locale-base-8.1.0_82533
psa-locale-base-8.1.0_82533: "/databases/mysql41-server" non-existent -- dependency list incomplete
*** Error code 1
Stop in /usr/ports/swsoft/psa-locale-base.
*** Error code 1
Stop in /usr/ports/swsoft/psa.
** Command failed [exit code 1]: /usr/bin/script -qa /tmp/portupgrade.12277.0 env make ARCH=i386 OPSYS=FreeBSD OSREL=6.1 OSVERSION=601000 SYSTEMVERSION= reinstall
** Fix the installation problem and try again.
** Listing the failed packages (*:skipped / !:failed)
! swsoft/psa (install error)
---> Packages processed: 0 done, 0 ignored, 0 skipped and 1 failed
*** Error code 1
and when i go to see /usr/ports/swsoft/psa-locale-base/Makefile
it's had one line that seem ..
RUN_DEPENDS+= mysql_waitpid:/databases/mysql41-server
i think that's make error in mysql_waitpid: << and what is this , can anyone have same problem and solve this problem .. thank you
*** Error code 1
*** Error code 1
*** Error code 1
