Plesk 8.11 upgrade to 8.2 problem
I have the same problem, when i try to login to plesk as Admin, i have the below error in the home page :
Code:
MySQL query failed: Unknown column 'uid' in 'field list'
0: /usr/local/psa/admin/plib/common_func.php3:216
    db_query(string 'select `id`,`cr_date`,`cname`,`pname`,`login`,`account_id`,`status`,`phone`,`fax`,`email`,`address`,`city`,`state`,`pcode`,`country`,`locale`,`limits_id`,`params_id`,`perm_id`,`pool_id`,`logo_id`,`tmpl_id`,`sapp_pool_id`,`uid`,`ownership` from clients where `id`=4')
1: /usr/local/psa/admin/plib/class.Table.php:180
    Table->select()
2: /usr/local/psa/admin/plib/class.cObject.php:443
    cObject->fetchAttrsFromTable_()
3: /usr/local/psa/admin/plib/class.Client.php3:74
    Client->Client(integer '4')
4: /usr/local/psa/admin/plib/common_func.php3:2867
    objectMaker(string 'Client', integer '4')
5: /usr/local/psa/admin/plib/ui/client.php:69
    plesk__client->getDisplayName()
6: /usr/local/psa/admin/plib/UIPointer.php:846
    UIPointer->getCaption(string 'description', NULL null, NULL null, object of type UserAdmin, NULL null, string '')
7: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:515
    DashboardElement->getDefaultCaption(string 'description', object of type UserAdmin, NULL null)
8: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:508
    DashboardElement->getCaption(string 'description', object of type UserAdmin, NULL null)
9: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:1456
    DashboardElement_shortcut->renderHtml(object of type UserAdmin, NULL null)
10: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:584
    DashboardElement->renderHtml_shortcuts(array, object of type UserAdmin, NULL null)
11: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:554
    DashboardElement->renderHtml_common(array, object of type UserAdmin, NULL null)
12: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:1097
    DashboardElement_tab->renderHtml_content(boolean false, object of type UserAdmin, NULL null)
13: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:1047
    DashboardElement_tabs->renderHtml(object of type UserAdmin, NULL null)
14: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:557
15: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:944
    DashboardElement_section->renderHtml(object of type UserAdmin, NULL null)
16: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:557
17: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:564
    DashboardElement->renderHtml(object of type UserAdmin, NULL null)
18: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:898
    DashboardElement_column->renderHtml(object of type UserAdmin, NULL null)
19: /usr/local/psa/admin/plib/dashboard/DashboardElement.php:571
    DashboardElement::renderHtml_columns(array, object of type UserAdmin, NULL null)
20: /usr/local/psa/admin/plib/dashboard/Dashboard.php:197
    Dashboard::renderHtml(array, object of type UserAdmin)
21: /usr/local/psa/admin/plib/dashboard/DashboardForm.php:95
    DashboardForm->assign(array, object of type UserAdmin)
22: /usr/local/psa/admin/plib/dashboard/DashboardLocation.php:55
    DashboardLocation->accessItem(string 'GET', NULL null)
23: /usr/local/psa/admin/plib/UIPointer.php:520
    UIPointer->access(string 'GET')
24: /usr/local/psa/admin/htdocs/plesk.php:19
When i click on a domain, i have the same error as Nunor
Jesus christ these people working for PLESK are a JOKE. Have they still not learned their damned lesson from all the failed upgrades in the past?
same Problem here
really disappointed with plesk, i was use directadmin and it never happened something like that.
