Plesk Firewall Module: ip6tables/IPv6 problem with outgoing connections.
BoMbY
Okay, maybe this is a Kernel or Virtuozzo problem, or something like this, because this is running on a vServer - but maybe someone got an idea? This are the ip6tables rules generated by the Plesk Firewall module on my CentOS 6.4 vServer:
Code:
Chain INPUT (policy DROP)
target     prot opt source               destination
ACCEPT     all      anywhere             anywhere            state RELATED,ESTABLISHED
REJECT     tcp      anywhere             anywhere            tcp flags:!FIN,SYN,RST,ACK/SYN state NEW reject-with tcp-reset
DROP       all      anywhere             anywhere            state INVALID
ACCEPT     tcp      2001:4dd0:XXXX::/48  anywhere            tcp dpt:12443
DROP       tcp      anywhere             anywhere            tcp dpt:12443
ACCEPT     tcp      2001:4dd0:XXXX::/48  anywhere            tcp dpt:11443
ACCEPT     tcp      2001:4dd0:XXXX::/48  anywhere            tcp dpt:11444
DROP       tcp      anywhere             anywhere            tcp dpt:11443
DROP       tcp      anywhere             anywhere            tcp dpt:11444
ACCEPT     tcp      2001:4dd0:XXXX::/48  anywhere            tcp dpt:8447
DROP       tcp      anywhere             anywhere            tcp dpt:8447
ACCEPT     tcp      2001:4dd0:XXXX::/48  anywhere            tcp dpt:pcsync-https
ACCEPT     tcp      2001:4dd0:XXXX::/48  anywhere            tcp dpt:cddbp-alt
DROP       tcp      anywhere             anywhere            tcp dpt:pcsync-https
DROP       tcp      anywhere             anywhere            tcp dpt:cddbp-alt
ACCEPT     tcp      anywhere             anywhere            tcp dpt:http
ACCEPT     tcp      anywhere             anywhere            tcp dpt:https
ACCEPT     tcp      anywhere             anywhere            tcp dpt:ftp
ACCEPT     tcp      2001:4dd0:XXXX::/48  anywhere            tcp dpt:ssh
DROP       tcp      anywhere             anywhere            tcp dpt:ssh
ACCEPT     tcp      anywhere             anywhere            tcp dpt:submission
ACCEPT     tcp      anywhere             anywhere            tcp dpt:smtp
ACCEPT     tcp      anywhere             anywhere            tcp dpt:urd
ACCEPT     tcp      anywhere             anywhere            tcp dpt:pop3
ACCEPT     tcp      anywhere             anywhere            tcp dpt:pop3s
ACCEPT     tcp      anywhere             anywhere            tcp dpt:imap
ACCEPT     tcp      anywhere             anywhere            tcp dpt:imaps
ACCEPT     tcp      2001:4dd0:XXXX::/48  anywhere            tcp dpt:poppassd
DROP       tcp      anywhere             anywhere            tcp dpt:poppassd
DROP       tcp      anywhere             anywhere            tcp dpt:mysql
DROP       tcp      anywhere             anywhere            tcp dpt:postgres
DROP       tcp      anywhere             anywhere            tcp dpt:ogs-server
DROP       tcp      anywhere             anywhere            tcp dpt:glrpc
DROP       udp      anywhere             anywhere            udp dpt:netbios-ns
DROP       udp      anywhere             anywhere            udp dpt:netbios-dgm
DROP       tcp      anywhere             anywhere            tcp dpt:netbios-ssn
DROP       tcp      anywhere             anywhere            tcp dpt:microsoft-ds
ACCEPT     udp      2001:4dd0:XXXX::/48  anywhere            udp dpt:openvpn
DROP       udp      anywhere             anywhere            udp dpt:openvpn
ACCEPT     udp      anywhere             anywhere            udp dpt:domain
ACCEPT     tcp      anywhere             anywhere            tcp dpt:domain
ACCEPT     ipv6-icmp    anywhere             anywhere            ipv6-icmp type 134 code 0
ACCEPT     ipv6-icmp    anywhere             anywhere            ipv6-icmp type 135 code 0
ACCEPT     ipv6-icmp    anywhere             anywhere            ipv6-icmp type 136 code 0
ACCEPT     ipv6-icmp    anywhere             anywhere            ipv6-icmp type 137 code 0
ACCEPT     ipv6-icmp    anywhere             anywhere            ipv6-icmp type 128 code 0
ACCEPT     ipv6-icmp    anywhere             anywhere            ipv6-icmp type 129 code 0
Chain FORWARD (policy DROP)
Chain OUTPUT (policy DROP)
And the problem is for once, this:
Code:
# ping6 blog.fefe.de
PING blog.fefe.de(2001:4d88:ffff:ffff:d0:b723:863f:2) 56 data bytes
ping: sendmsg: Operation not permitted
And for a outgoing IPv6 HTTP connection, for example:
Code:
# wget blog.fefe.de
--2013-06-21 14:20:22--  http://blog.fefe.de/
Resolving blog.fefe.de... 2001:4d88:ffff:ffff:d0:b723:863f:2, 31.15.64.162
Connecting to blog.fefe.de|2001:4d88:ffff:ffff:d0:b723:863f:2|:80...
The connection just hangs there, and will timeout eventually. Like the ACKs are not coming through, or something like that. IPv4 is working fine, and if I purge all ip6tables rules and set INPUT and OUTPUT to ACCEPT, it's working as well. What could this be?
Thanks and Regards,
BoMbY
