Plesk Panel 11.5.30 Cron problem
JuricaK
Hello,
I need a command for cron job that runs the php file with the argument.
For example (php -q httpdocs/cron.php quick) where "quick" argument.
On webmin panel command (php -q /home /user/public_html/cron.php quick) works great.
Until now I always got an error
-> httpdocs/cron.php: line 1: ?Php: No such file or directory
Please help
thanks
could you please check the first line of cron.php?
It probably starts with ?Php but it should start with <?php
Regards,
Kristian
Regards,
Kristian
Hi Kristian,
my cron.php looks like:
<?php
require_once('config.php');
Tnx for your reply.
same for config.php? :)
As long as this command does not run by shell, you won't be able to setup a working cron.
As we do not know what you have setup or if you have modified some files with some windows Editor or similar,
it's hard to tell. The issue is not Plesk related.
Regards,
Kristian
