PMM mysql charset problems - pls help
N
next-step
Big problem during migration:
below is the example of migration results
I'm sure its charset problem
In the original server psa database has cp1251 charset.
Please help how can I rectify this?
Code:
Execution of /usr/local/psa/bin/client --update golden -phone +7\ 923\ 333\ 7838 -city  -company \ - -country RU -zip 633009 -state  failed with return code 1.
Stderr is
An error occured during client update: Unable to update client data: cObject::update() failed: Some fields wrong or has inproper values: 'state' = .
  	Execution of /usr/local/psa/bin/client --update golden -country RU -zip 633009 -state  failed with return code 1.
Stderr is
Plesk (starting from 7.x) stores all records in database in UTF8. If you set system locale on both source and destination hosts to unicode - you greatly reduce probability of encoding problems.
Plesk don't like particular 'state' field. It is limited to just 50 characters and your double-encoded 'Новосибирская' have 54 symbols in it...
