wperror500
When you see the WordPress white screen of death error on your website, you should try to eliminate the error by trying these methods
- Locate the plugins on the dashboard and deactivate them if they are corrupted
- Uninstall the current theme and replace it with the default theme
- Make a new .htaccess file and delete the old one (make sure all the rewrite commands and codes written correctly)
- Raise the PHP limit of the WordPress website
- Flush our stored cookies and cache from the browser
- Ensure that you are using correct database credentials
- Remove corrupt WordPress file restore the default file
- Defected themes need to be eliminated from the website
- Flush out the incompatible plugins from the website
- Contact your web host if the situation is out of your hand
