problem installing mod_cloudflare
LegolasTheElf
Basic Pleskian
hi all,
i've plesk 11.0.9 microupdate #47 installed over a debian Debian 6.0.2, and i'm trying to install mod-cloudflare.
if i try via web, i found the modules, but is not selectable, so i can't install it.
if i try via console running autoinstaller, they show me mod cloudflare with an [!] mark and if i try to select it autoinstaller retuns me an error and don't permit to me not to install it neither remove it.
same thing happening over 2 server, the second installed on Debian 6.0.4.
seems to me that mod-cloudflare isn't available into the repository... can it be?
any suggestions?
excuse me Igor.... WHY isn't supported?
i've 3 server, 2 debian and 1 ubuntu. in ubuntu autoinstall have put the mod_cloudflare on in few second.
ubuntu use the same .deb package of debian, and it's debian derivated as all we know.
it's totally the same system as far as we know.
so, repeat, WHY?
are there any motivation for this? CloudFlare seems to be one of the best parallels partner, debian is fully supported, so are there any reason for that?
because if i have to install with apt-get install mod-cloudflare i've no problem with it, but if this can be a source for problem tomorrow i've to know!
if it's simple a forgotten package into parallels debian repo, please fix it (takes few seconds), if it's not and there are reason for that, we need to know why...
Strange. We have it for 64bit Debian...
We will check it and I update thread.
hi igor, any news?
we want to implement cloudflare and parallels partnership and we need to gat 3 sites under test for it, and we want to put a site over every server...
I have discussed it with responsible persons and looks like it is our fault. We will fix it soon. Sorry.
if it can be useful , this is the output of /opt/psa/admin/bin/autoinstaller (sorry, we are localized in italianand i've to shorten it... )
Selezionare la sorgente del software del prodotto
È possibile installare i prodotti usando una delle seguenti sorgenti:
*Supporto locale
* Server Ufficiale di Parallels
* Un altro sito di rete
Impostazioni attuali:
Installare i prodotti da Server Parallels
Installare i pacchetti di sistema richiesti da Server Parallels
Archiviare i file scaricati in: /root/parallels
N) Pagina successiva; P) Indietro; Q) Annulla l'installazione
S) Cambia la sorgente; T) Cambia la directory di destinazione;
Seleziona un'azione e premi INVIO [N]:
Configurazione del Proxy HTTP
Se si è dietro un firewall e si usa un proxy HTTP, è necessario specificare il server proxy in basso.
Se il proxy richiede l'autenticazione, selezionare "Usare autenticazione"
e specificare il nome utente e la password
Non usare proxy.
"N) Pagina successiva; P) Indietro; Q) Annulla l'installazione;
S) Seleziona il server proxy; A) Usa autenticazione;
Seleziona l'azione richiesta [N]: [sp]"
Verifica dei pacchetti installati...
Download del file in corso products.inf3: 100% completato.
Download del file in corso plesk.inf3: 13%..23%..30%..40%..52%..63%..70%..80%..90%..100% completato.
Download del file in corso ppsmbe.inf3: 59%..90%..100% completato.
Download del file in corso sitebuilder.inf3: 35%..74%..100% completato.
Download del file in corso sso.inf3: 78%..100% completato.
Download del file in corso setemplates.inf3: 44%..100% completato.
Download del file in corso pp-sitebuilder.inf3: 26%..40%..90%..100% completato.
Download del file in corso billing.inf3: 17%..26%..39%..71%..89%..98%..100% completato.
Download del file in corso mysql.inf3: 100% completato.
Download del file in corso apache.inf3: 100% completato.
Download del file in corso nginx.inf3: 100% completato.
Selezionare i prodotti desiderati e le loro versioni
Sono disponibili le seguenti versioni del prodotto:
1. [*] Parallels Plesk Panel
2. (*) Parallels Plesk Panel 11.0.9 (stable) (currently installed)
N) Vai alla pagina successiva; P) Vai alla pagina precedente; Q) Annulla l'installazione
Per selezionare una versione, digitare il relativo numero;
Selezionare un'azione [N]:
Download del file in corso PSA_11.0.9/plesk-11.0.9-deb6.0-i386.inf3: 10%..21%..32%..47%..72%..83%..94%..100% completato.
Download del file in corso PSA_11.0.9/plesk-patches-11.0.9-deb6.0-i386.inf3: 13%..30%..40%..57%..68%..76%..86%..100% completato.
Download del file in corso SITEBUILDER_11.0.10/sitebuilder-11.0.10-deball-all.inf3: 100% completato.
Download del file in corso BILLING_11.0.9/billing-11.0.9-deball-all.inf3: 100% completato.
Download del file in corso NGINX_1.3.0/nginx-1.3.0-deb6.0-i386.inf3: 100% completato.
Sincronizzazione dei file index del paccheto APT di Debian in corso...
Hit http://mirror.ovh.net squeeze Release.gpg
Ign http://mirror.ovh.net/debian/ squeeze/main Translation-en
Hit http://mirror.ovh.net/debian/ squeeze/main Translation-it
Hit http://mirror.ovh.net squeeze-updates Release.gpg
Ign http://mirror.ovh.net/debian/ squeeze-updates/main Translation-en
Ign http://mirror.ovh.net/debian/ squeeze-updates/main Translation-it
Hit http://mirror.ovh.net squeeze/main Sources
Hit http://security.debian.org squeeze/updates Release.gpg
Hit http://mirror.ovh.net squeeze/main i386 Packages
Hit http://mirror.ovh.net squeeze-updates/main Sources/DiffIndex
Hit http://mirror.ovh.net squeeze-updates/main i386 Packages/DiffIndex
Ign http://security.debian.org/ squeeze/updates/main Translation-en
Ign http://security.debian.org/ squeeze/updates/main Translation-it
Hit http://dl.google.com stable Release.gpg
Ign http://dl.google.com/linux/mod-pagespeed/deb/ stable/main Translation-en
Hit http://security.debian.org squeeze/updates/main Sources
Hit http://security.debian.org squeeze/updates/main i386 Packages
Ign http://dl.google.com/linux/mod-pagespeed/deb/ stable/main Translation-it
Hit http://dl.google.com stable/main i386 Packages
Ign https://autoinstall.plesk.com squeeze Release.gpg
Ign https://autoinstall.plesk.com/debian/PSA_11.0.9/ squeeze/all Translation-en
Ign https://autoinstall.plesk.com/debian/PSA_11.0.9/ squeeze/all Translation-it
Ign https://autoinstall.plesk.com all Release.gpg
Ign https://autoinstall.plesk.com/debian/SITEBUILDER_11.0.10/ all/all Translation-en
Ign https://autoinstall.plesk.com/debian/SITEBUILDER_11.0.10/ all/all Translation-it
Ign https://autoinstall.plesk.com/debian/BILLING_11.0.9/ all/all Translation-en
Ign https://autoinstall.plesk.com/debian/BILLING_11.0.9/ all/all Translation-it
Get:1 https://autoinstall.plesk.com squeeze/all i386 Packages [20.0 kB]
Ign https://autoinstall.plesk.com all/all i386 Packages
Get:2 https://autoinstall.plesk.com all/all i386 Packages [912 B]
Get:3 https://autoinstall.plesk.com all/all i386 Packages [771 B]
Fetched 21.6 kB in 5s (3901 B/s)
Reading package lists...
Warning: not connected 'contrib' repository section
Warning: not connected 'non-free' repository section
Rilevamento dei componenti del pacchetto installati.
Lista di principali componenti per Parallels Plesk Panel
0 di 36 componenti selezionati
Seleziona i componenti di Parallels Plesk Panel che desideri installare:
1. [=] Base packages of Plesk
2. [=] Plesk Updater
3. [=] PostgreSQL server support
4. [=] Plesk migration manager
5. [=] Health monitor
6. [=] Payment gateway and registrar modules adapted to Business Manager
7. [=] Parallels Web Presence Builder
8. [=] Customer & Business Manager (recommended for shared hosting)
9. [ ] Nginx reverse proxy support
10. [=] PHP5 support
11. [=] Apache web server support
12. [=] MySQL server support
13. [.] <+> Plesk hosting features // 8 of 8 components selected
Different mailservers
14. (=) Qmail mailserver
15. ( ) Postfix mailserver
16. [.] <+> Additional Plesk extensions // 3 of 6 components selected
17. [ ] <+> Game servers // 0 of 1 components selected
18. [=] <+> Additional mail services // 4 of 4 components selected
19. [.] <+> Server backup solutions // 1 of 2 components selected
20. [=] <+> Plesk webmails support // 2 of 2 components selected
N) Pagina avanti; P) Indietro; Q) Annulla l'installazione;
A) Seleziona tutto; D) Deseleziona tutto;
Inserire un numero per attivare il componente o per visualizzare il gruppo;Digita un numero o un carattere per l'azione desiderata [N]: 13
Lista di componenti primari / hosting
Seleziona i componenti che desideri installare:
1. [=] Bandwidth Limiter For Apache support (mod_bw)
2. [=] Apache ASP support
3. [=] Tomcat Java Servlets support
4. [=] Apache mod_python module
5. [=] Ruby on Rails support
6. [=] ColdFusion support for Plesk
7. [=] MIVA Empresa support
8. [!] Cloudflare Apache Module
(A) Seleziona tutto, (D) Deseleziona tutto,
(L) Torna alla lista di componenti primari, (Q) Annulla l'installazione
Per selezionare o deselezionare un componente, inserire il suo numero;
Digita un numero o un carattere per l'azione desiderata [L]: 8
Il componente plesk/mod-cloudflare non è disponibile.
(premi Invio per continuare)
Digita un numero o un carattere per l'azione desiderata [L]: Q
please, check again.
i've verified from machines located in italy and in france, and also via HTTP all we can say is this:
Index of /PSA_11.0.9/dist-deb-Debian-6.0-i386/opt/cloudflare
Icon Name Last modified Size Description[DIR] Parent Directory -
Apache/2.0.54 (Fedora) Server at origin.autoinstall.plesk.com Port 80
as you can see... no package here.
just to make a check, i've tried to navigate to another directory, like the one of atmail, and there you can see the package, like this:
Index of /PSA_11.0.9/dist-deb-Debian-6.0-i386/opt/atmail
[ ] psa-atmail_1.05-debian6.0.build110120606.18_all.deb 06-Jun-2012 07:37 3.3M
what kind of problem can we have at this point?
on first server:
user@hosting:~$ wget https://autoinstall.plesk.com/PSA_1...od-cloudflare_1.1.1-61fa04b.12061915_i386.deb
--2013-05-15 13:09:08-- https://autoinstall.plesk.com/PSA_1...od-cloudflare_1.1.1-61fa04b.12061915_i386.deb
Resolving autoinstall.plesk.com... 93.184.221.133
Connecting to autoinstall.plesk.com|93.184.221.133|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2013-05-15 13:09:09 ERROR 404: Not Found.
user@hosting:~$ host autoinstall.plesk.com
autoinstall.plesk.com is an alias for ne.edgecastcdn.net.
ne.edgecastcdn.net has address 93.184.221.133
from second server:
user@secondhosting:~$ wget https://autoinstall.plesk.com/PSA_1...od-cloudflare_1.1.1-61fa04b.12061915_i386.deb
--2013-05-15 13:13:37-- https://autoinstall.plesk.com/PSA_1...od-cloudflare_1.1.1-61fa04b.12061915_i386.deb
Risoluzione di autoinstall.plesk.com... 93.184.221.133
Connessione a autoinstall.plesk.com|93.184.221.133|:80... connesso.
HTTP richiesta inviata, in attesa di risposta... 404 Not Found
2013-05-15 13:13:37 ERRORE 404: Not Found.
user@secondhosting:~$ host autoinstall.plesk.com
all servers tested before are located in france into a primary server farm.
i've also tested from my pc, located in italy, with totally diferent network configuration, windows-based.
via web with a browser i've this page:
Not Found
The requested URL /PSA_11.0.9/dist-deb-Debian-6.0-i386/opt/cloudflare/libapache2-mod-cloudflare_1.1.1-61fa04b.12061915_i386.deb was not found on this server.
i also try http://93.184.221.133/PSA_11.0.9/di...od-cloudflare_1.1.1-61fa04b.12061915_i386.deb
and i recieve an error 404 - not found
i've checked the ip like this:
C:\Users\legolas>host autoinstall.plesk.com
C:\Users\legolas>ping autoinstall.plesk.com
Esecuzione di Ping ne.edgecastcdn.net [93.184.221.133] con 32 byte di dati:
Risposta da 93.184.221.133: byte=32 durata=48ms TTL=56
Risposta da 93.184.221.133: byte=32 durata=49ms TTL=56
Statistiche Ping per 93.184.221.133:
Pacchetti: Trasmessi = 4, Ricevuti = 4,
Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
Minimo = 48ms, Massimo = 49ms, Medio = 48ms
C:\Users\legolas>wget https://autoinstall.plesk.com/PSA_11.0.9/dist-deb-Debian-6.
--13:26:33-- https://autoinstall.plesk.com/PSA_11.0.9/dist-deb-Debian-6.0-i386/o
=> `libapache2-mod-cloudflare_1.1.1-61fa04b.12061915_i386.deb'
13:26:34 ERROR 404: Not Found.
C:\Users\legolas>
Looks like our mistake. Sorry.
It will be fixed very soon.
