• The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
Problem installing Plesk Panel
AlexNL
When I try to install Plesk Panel on my VPS server I constantly get a error and the installation is aborted. It doesn't matter if I do it by web-interface, ssh command line or even the one-click-installer. It shows the errors below. I have the error log attached to this topic. The server runs Debian 6.
Installation started in background
Checking whether the package dependencies are resolved.
E: Broken packages
---X--- `apt-get` output ---------------------
Reading package lists...
Building dependency tree...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
plesk-core : Depends: dnsutils but it is not going to be installed
---------------------- `apt-get` output ---X---
Collecting error details into log file...
Error: Installation will not continue
Not all packages were installed.
Please, contact product technical support.
Please help.
  • parallels-installation-log.txt
Have you tried install dnsutils package before Plesk installation? And why you do not use Virtuozzo ez-template for Plesk installation if you have Virtuozzo VPS?
This is the way my webhosting provider told me to install Plesk Panel on my VPS. Have found a ez template, but can't find how to install a template. Will try to look how to work with templates or install dnsutils first.
BTW, Virtuozzo ez-template can be installed to VPS only from Virtuozzo hardware node side.
