Question Problem installing site import
chrysllercs
Ubuntu 16.04
Plesk Obsidian v18.0.34_build1800210325.10
I'm trying to install site import but it's giving the following error
I already tested via ssh but still giving the same error : plesk bin extension --install site-import
  • A execução de post-install.php falhou com a seguinte mensagem: [2022-08-27 14:43:47.105] ERR [panel] Execution plesk-migrator-post-install-packages.sh has failed with exit code 1, stdout: Bootstrapping dependencies for ubuntu xenial...
  • , stderr: ERROR:__main__:Command '['apt-get', '-qq', 'update']' returned non-zero exit status 100
  • stdout:
  • stderr:W: Target Packages (all/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/plesk-ext-panel-migrator.list:1 and /etc/apt/sources.list.d/plesk-ext-site-import.list:1
  • W: Target Packages (all/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/plesk-ext-panel-migrator.list:1 and /etc/apt/sources.list.d/plesk-ext-site-import.list:1
  • W: Target Translations (all/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/plesk-ext-panel-migrator.list:1 and /etc/apt/sources.list.d/plesk-ext-site-import.list:1
  • W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://dl.google.com/linux/mod-pagespeed/deb stable Release: The following signatures were invalid: KEYEXPIRED 1555048520 KEYEXPIRED 1579833932 KEYEXPIRED 1658427182 KEYEXPIRED 1658427182 KEYEXPIRED 1555048520 KEYEXPIRED 1579833932 KEYEXPIRED 1658427182 KEYEXPIRED 1555048520 KEYEXPIRED 1579833932 KEYEXPIRED 1658427182
  • W: The repository 'https://autoinstall.plesk.com/pool/PSA_18.0.34_5691 xenial Release' does not have a Release file.
  • W: Failed to fetch http://dl.google.com/linux/mod-pagespeed/deb/dists/stable/Release.gpg The following signatures were invalid: KEYEXPIRED 1555048520 KEYEXPIRED 1579833932 KEYEXPIRED 1658427182 KEYEXPIRED 1658427182 KEYEXPIRED 1555048520 KEYEXPIRED 1579833932 KEYEXPIRED 1658427182 KEYEXPIRED 1555048520 KEYEXPIRED 1579833932 KEYEXPIRED 1658427182
  • E: Failed to fetch https://autoinstall.plesk.com/pool/PSA_18.0.34_5691/dists/xenial/extras/binary-i386/Packages 404 Not Found [IP: 89.187.173.12 80]
  • W: Some index files failed to download. They have been ignored, or old ones used instead.
  • W: Target Packages (all/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/plesk-ext-panel-migrator.list:1 and /etc/apt/sources.list.d/plesk-ext-site-import.list:1
  • exit status 1
  • 0: /opt/psa/admin/plib/pm/ApiCli.php:234
  • pm_ApiCli::filterResult(string 'plesk-migrator-post-install-packages.sh', integer '1', string 'Bootstrapping dependencies for ubuntu xenial...
  • ', string 'ERROR:__main__:Command '['apt-get', '-qq', 'update']' returned non-zero exit status 100
  • stdout:
  • std...', integer '5')
  • 1: /opt/psa/admin/plib/pm/ApiCli.php:227
  • pm_ApiCli::execWithPipes(string 'plesk-migrator-post-install-packages.sh', string ''/opt/psa/admin/bin/modules/site-import/plesk-migrator-post-install-packages.sh' ', integer '5', array)
  • 2: /opt/psa/admin/plib/pm/ApiCli.php:98
  • pm_ApiCli::callSbin(string 'plesk-migrator-post-install-packages.sh')
  • 3: /opt/psa/admin/plib/modules/site-import/scripts/plesk-migrator-post-install.php:9
  • postInstallPleskMigrator(NULL null)
  • 4: /opt/psa/admin/plib/modules/site-import/scripts/post-install.php:12
  • ERROR: pm_Exception_ResultException: Execution plesk-migrator-post-install-packages.sh has failed with exit code 1, stdout: Bootstrapping dependencies for ubuntu xenial...
  • stdout:
  • exit status 1
  • (ApiCli.php:234)
Try to apply fix from this KB article: https://support.plesk.com/hc/en-us/...ed-deb-dists-stable-Release-gpg-is-not-signed
I did the step by step but I was not successful!
root@servidor:~# grep -ir pagespeed /etc/apt*
/etc/apt/sources.list.d/mod-pagespeed.list.save:deb http://dl.google.com/linux/mod-pagespeed/deb/ stable main
root@servidor:~# mv /etc/apt/sources.list.d/mod-pagespeed.list ~/
mv: cannot stat '/etc/apt/sources.list.d/mod-pagespeed.list': No such file or directory
root@servidor:~# apt update
Hit:1 Index of /PMM_0.1.11 xenial InRelease
Ign:2 https://autoinstall.plesk.com/pool/PSA_18.0.34_5691 xenial InRelease
Hit:3 Index of /ubuntu/PHP56_17 xenial InRelease
Hit:4 Index of /ubuntu/PHP70_17 xenial InRelease
Hit:5 Index of /pool/PHP_7.1.33_96 xenial InRelease
Hit:6 Index of /pool/PHP_7.2.34_150 xenial InRelease
Hit:7 Index of /pool/PHP_7.3.27_219 xenial InRelease
Err:8 https://autoinstall.plesk.com/pool/PSA_18.0.34_5691 xenial Release
404 Not Found [IP: 89.187.173.11 80]
Hit:9 Index of /ubuntu xenial-security InRelease
Hit:10 Index of /ubuntu xenial InRelease
Hit:11 Index of /kernelcare-debian/9/ stable InRelease
Hit:12 Index of /ondrej/apache2/ubuntu xenial InRelease
Hit:13 Index of /ubuntu xenial InRelease
Hit:14 Index of /ubuntu xenial-updates InRelease
Hit:15 Index of /infra/ubuntu/ xenial-infra-security InRelease
Hit:16 Index of /infra/ubuntu/ xenial-infra-updates InRelease
Reading package lists... Done
E: The repository 'https://autoinstall.plesk.com/pool/PSA_18.0.34_5691 xenial Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
