stefanoste
I have just installed new from scratch and I moved the website but for some reason keep crashing , I keep having multiple process from
Code:
opt/plesk/php/5.6/bin/php-cgi -c /var/www/vhost/system/websites/etc/php.ini
[code]
which overload the server and keep crashing every 10 minute I really hope someone can please advice , I will attach error log
[code]
[Fri Mar 03 19:27:16 2017] [notice] ModSecurity: APR compiled version="1.3.9"; loaded version="1.3.9"
[Fri Mar 03 19:27:16 2017] [notice] ModSecurity: PCRE compiled version="7.8 "; loaded version="7.8 2008-09-05"
[Fri Mar 03 19:27:16 2017] [notice] ModSecurity: LUA compiled version="Lua 5.1"
[Fri Mar 03 19:27:16 2017] [notice] ModSecurity: LIBXML compiled version="2.7.6"
[Fri Mar 03 19:27:16 2017] [notice] ModSecurity: Original server signature: Apache
[Fri Mar 03 19:27:16 2017] [notice] ModSecurity: Status engine is currently disabled, enable it by set SecStatusEngine to On.
[Fri Mar 03 19:27:16 2017] [warn] No JkLogFile defined in httpd.conf. Using default /etc/httpd/logs/mod_jk.log
[Fri Mar 03 19:27:16 2017] [warn] No JkShmFile defined in httpd.conf. Using default /etc/httpd/logs/jk-runtime-status
[Fri Mar 03 19:27:16 2017] [notice] Digest: generating secret for digest authentication ...
[Fri Mar 03 19:27:16 2017] [notice] Digest: done
[Fri Mar 03 19:27:17 2017] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 48 bytes)
[Fri Mar 03 19:27:17 2017] [notice] mod_bw : Version 0.92 - Initialized [0 Confs]
[Fri Mar 03 19:27:17 2017] [warn] RSA server certificate CommonName (CN) `Parallels Panel' does NOT match server name!?
[Fri Mar 03 19:27:17 2017] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Mar 03 19:27:17 2017] [warn] No JkLogFile defined in httpd.conf. Using default /etc/httpd/logs/mod_jk.log
[Fri Mar 03 19:27:17 2017] [warn] No JkShmFile defined in httpd.conf. Using default /etc/httpd/logs/jk-runtime-status
[Fri Mar 03 19:27:17 2017] [error] python_init: Python version mismatch, expected '2.6.5', found '2.6.6'.
[Fri Mar 03 19:27:17 2017] [error] python_init: Python executable found '/usr/bin/python'.
[Fri Mar 03 19:27:17 2017] [error] python_init: Python path being used '/usr/lib64/python26.zip:/usr/lib64/python2.6/:/usr/lib64/python2.6/plat-linux2:/usr/$
[Fri Mar 03 19:27:17 2017] [notice] mod_python: Creating 4 session mutexes based on 256 max processes and 0 max threads.
[Fri Mar 03 19:27:17 2017] [notice] mod_python: using mutex_directory /tmp
[Fri Mar 03 19:27:17 2017] [notice] Apache/2.2.15 (Unix) DAV/2 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips Apache mod_fcgid/2.3.9 mod_jk/1.2.40 mod_python/3.3.1 Pyth$
[Fri Mar 03 19:27:23 2017] [notice] caught SIGTERM, shutting down
[Fri Mar 03 19:27:32 2017] [error] FastCGI process 26210 still did not exit, terminating forcefully
[Fri Mar 03 19:27:35 2017] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Mar 03 19:27:36 2017] [warn] RSA server certificate CommonName (CN) `Parallels Panel' does NOT match server name!?
[Fri Mar 03 19:27:36 2017] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Mar 03 19:27:36 2017] [notice] ModSecurity for Apache/2.9.0 (http://www.modsecurity.org/) configured.
[Fri Mar 03 19:27:36 2017] [notice] ModSecurity: APR compiled version="1.3.9"; loaded version="1.3.9"
[Fri Mar 03 19:27:36 2017] [notice] ModSecurity: PCRE compiled version="7.8 "; loaded version="7.8 2008-09-05"
[Fri Mar 03 19:27:36 2017] [notice] ModSecurity: LUA compiled version="Lua 5.1"
[Fri Mar 03 19:27:36 2017] [notice] ModSecurity: LIBXML compiled version="2.7.6"
[Fri Mar 03 19:27:36 2017] [notice] ModSecurity: Original server signature: Apache
[Fri Mar 03 19:27:36 2017] [notice] ModSecurity: Status engine is currently disabled, enable it by set SecStatusEngine to On.
[Fri Mar 03 19:27:36 2017] [warn] No JkLogFile defined in httpd.conf. Using default /etc/httpd/logs/mod_jk.log
[Fri Mar 03 19:27:36 2017] [warn] No JkShmFile defined in httpd.conf. Using default /etc/httpd/logs/jk-runtime-status
[Fri Mar 03 19:27:36 2017] [notice] Digest: generating secret for digest authentication ...
[Fri Mar 03 19:27:36 2017] [notice] Digest: done
[Fri Mar 03 19:27:37 2017] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 48 bytes)
[Fri Mar 03 19:27:37 2017] [notice] mod_bw : Version 0.92 - Initialized [0 Confs]
[Fri Mar 03 19:27:37 2017] [warn] RSA server certificate CommonName (CN) `Parallels Panel' does NOT match server name!?
[Fri Mar 03 19:27:37 2017] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Mar 03 19:27:37 2017] [warn] No JkLogFile defined in httpd.conf. Using default /etc/httpd/logs/mod_jk.log
[Fri Mar 03 19:27:37 2017] [warn] No JkShmFile defined in httpd.conf. Using default /etc/httpd/logs/jk-runtime-status
[Fri Mar 03 19:27:37 2017] [error] python_init: Python version mismatch, expected '2.6.5', found '2.6.6'.
[Fri Mar 03 19:27:37 2017] [error] python_init: Python executable found '/usr/bin/python'.
[Fri Mar 03 19:27:37 2017] [error] python_init: Python path being used '/usr/lib64/python26.zip:/usr/lib64/python2.6/:/usr/lib64/python2.6/plat-linux2:/usr/$
[Fri Mar 03 19:27:37 2017] [notice] mod_python: Creating 4 session mutexes based on 256 max processes and 0 max threads.
[Fri Mar 03 19:27:37 2017] [notice] mod_python: using mutex_directory /tmp
[Fri Mar 03 19:27:37 2017] [notice] Apache/2.2.15 (Unix) DAV/2 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips Apache mod_fcgid/2.3.9 mod_jk/1.2.40 mod_python/3.3.1 Pyth$
[code]
Please help me out I don't really want to reinstall all over again
Thx
