Gabe Blodget
I've had nothing but issues trying to restore a backup from another plesk installation.
Running Plesk 12 on CentOS 6.
Here's what happened, I installed a php extension which required php 5.4. Yum kindly updated our php version, which broke a couple of our sites. In trying to use yum to remove php 5.4, it also removed several components to plesk. I then attempted to reinstall plesk and restore our backups from the previous day, but ran into several errors related to the way plesk hashes passwords in backups (as I now had a new key to hash against, they wouldn't work right). I solved that problem by running the fix passwords utility from you guys. But now I'm getting the following errors, and I have no idea how to fix this. I suspect the first one is the main problem.
WARNING: (server object '') Execution of /usr/local/psa/bin/sw-engine-pleskrun /usr/local/sb/utils/bru.php --restore --log=stdout --file=/usr/local/psa/PMM/tmp/sb54DVSHeFh.zip --target=server_settings failed with return code 1.
Stderr is
# Error: Cannot execute query to database. #
WARNING: (client object 'aadelsberger') Failed deployment of domain localimpact4u.com
WARNING: () Execution of /usr/local/psa/admin/plib/api-cli/domain.php --create localimpact4u.com -owner '' -do-not-apply-skeleton -notify false -guid 75f2060a-3b61-49b4-84d7-7c2b730c1a93 -vendor-guid 8385bd43-516a-4067-9c42-0a22bad178d7 -creation-date 2014-06-29 -ip 76.74.239.37 -ignore-nonexistent-options failed with return code 1.
Stderr is
Wrong syntax for command's '-owner' parameter. '' does not match the pattern '/^[^\s]{1,255}$/'.
This second error repeats for every one of our domains.
Any help would be appreciated.
Stderr is
Stderr is
