Issue Problem starting services after update and restart
Nicola Urbinati
Basic Pleskian
Ubuntu 18.04.6 LTS
Version 18.0.48, last updated on Dec 7, 2022 05:20 PM
After update (7-12-2022) I can't seem to be able to start the following services:
systemd-timedated:
Code:
Jan 08 17:52:56 srvurb01.urbaman.it systemd[1]: Starting Time & Date Service...
-- Subject: Unit systemd-timedated.service has begun start-up
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- Unit systemd-timedated.service has begun starting up.
Jan 08 17:52:56 srvurb01.urbaman.it systemd[8750]: systemd-timedated.service: Failed to set up mount namespacing: No such file or directory
Jan 08 17:52:56 srvurb01.urbaman.it systemd[8750]: systemd-timedated.service: Failed at step NAMESPACE spawning /lib/systemd/systemd-timedated: No such file or directory
-- Subject: Process /lib/systemd/systemd-timedated could not be executed
-- The process /lib/systemd/systemd-timedated could not be executed and failed.
-- The error number returned by this process is 2.
Jan 08 17:52:56 srvurb01.urbaman.it systemd[1]: systemd-timedated.service: Main process exited, code=exited, status=226/NAMESPACE
Jan 08 17:52:56 srvurb01.urbaman.it systemd[1]: systemd-timedated.service: Failed with result 'exit-code'.
Jan 08 17:52:56 srvurb01.urbaman.it systemd[1]: Failed to start Time & Date Service.
-- Subject: Unit systemd-timedated.service has failed
-- Unit systemd-timedated.service has failed.
-- The result is RESULT.
snap.canonical-livepatch.canonical-livepatchd
Code:
Jan 08 17:58:43 srvurb01.urbaman.it audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snap.canonical-livepatch.canonical-livepatchd comm="systemd" exe="/lib/
Jan 08 17:58:43 srvurb01.urbaman.it audit[10651]: AVC apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="/snap/core/14399/usr/lib/snapd/snap-confine" name
Jan 08 17:58:43 srvurb01.urbaman.it audit[10651]: SYSCALL arch=c000003e syscall=165 success=no exit=-13 a0=413fe8 a1=7ffebae5c450 a2=0 a3=5000 items=0 ppid=1 pid=10651 auid=4294967295
Jan 08 17:58:43 srvurb01.urbaman.it audit: PROCTITLE proctitle=2F736E61702F636F72652F31343339392F7573722F6C69622F736E6170642F736E61702D636F6E66696E6500736E61702E63616E6F6E6963616C2D6C6
Jan 08 17:58:43 srvurb01.urbaman.it canonical-livepatch.canonical-livepatchd[10651]: cannot perform operation: mount --rbind /var/tmp /tmp/snap.rootfs_7qqS3V//var/tmp: Permission denie
Jan 08 17:58:43 srvurb01.urbaman.it systemd[1]: snap.canonical-livepatch.canonical-livepatchd.service: Main process exited, code=exited, status=1/FAILURE
Jan 08 17:58:43 srvurb01.urbaman.it systemd[1]: snap.canonical-livepatch.canonical-livepatchd.service: Failed with result 'exit-code'.
Jan 08 17:58:43 srvurb01.urbaman.it audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snap.canonical-livepatch.canonical-livepatchd comm="systemd" exe="/lib/s
Jan 08 17:58:43 srvurb01.urbaman.it systemd[1]: snap.canonical-livepatch.canonical-livepatchd.service: Service hold-off time over, scheduling restart.
Jan 08 17:58:43 srvurb01.urbaman.it systemd[1]: snap.canonical-livepatch.canonical-livepatchd.service: Scheduled restart job, restart counter is at 2.
-- Subject: Automatic restarting of a unit has been scheduled
plesk-ext-monitoring-hcd
see previous post
Probably due to different problems, I'm trying to keep them together for easier tracking.
Thank you!
