• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Resolved Problem tuning fail2ban
SalvadorS
Regular Pleskian
Debian 11
18.0.61
Hello,
I found a very nice article in plesk blog to block badbots with fail2ban. I have problems with ClaudeBot who is hitting the server all the time.
The problem is that I have some problems with the article.
First I edited /etc/fail2ban/filter.d/apache-badbots.conf as requested adding the line:
badbots = ClaudeBot|ClaudeBot/1\.0
As I want to block this bot only (as a test)
and then reload:
fail2ban-client reload plesk-apache-badbots
But I have an error:
2024-05-30 17:33:30,944 fail2ban [1464544]: ERROR Failed during configuration: No section: 'plesk-apache-badbots'
If you don´t tuch anything (in another server) and reload I received the same error.
So I checked again the file /etc/fail2ban/jail.local as the article say and the section in the file is called:
[plesk-apache-badbot]
And not
[plesk-apache-badbots]
(note the s)
So I added the lines under [plesk-apache-badbot] and restart:
Without an s. All ok now (it seems the article have this error), but when I test the filter:
fail2ban-regex /var/www/vhosts/domain.com/logs/access_ssl_log /etc/fail2ban/filter.d/apache-badbots.conf
The result is:
Lines: 7163 lines, 0 ignored, 0 matched, 7163 missed
So no line is checked...
So I can´t block the bot in the server. Any ideas?
Yes, you are right. It's exactly what I did and works!
If someone needs this in the future this is the filter I used to stop the bot:
[Definition]
badbotscustom = EmailCollector|WebEMailExtrac|TrackBack/1\.02|sogou music spider|(?:Mozilla/\d+\.\d+ )?Jorgee
badbots = ClaudeBot|ClaudeBot/1\.0|DataForSeoBot/1\.0|claudebot
failregex = ^(?:\[[^\]]*\] )?<ADDR> [^"]*"[^"]*" \d+ \S+ "[^"]*" "[^"]*(?:%(badbots)s|%(badbotscustom)s)[^"]*"$
ignoreregex =
datepattern = ^[^\[]*\[({DATE})
{^LN-BEG}
I will tune in in the future, but now claudebot is stopped (houndred of IPs....)
Hi
I have a plesk server in which I also have Asterisk VOIP installed. Everything is working. However, I am trying to use fail2ban within Plesk to capture and drop IPs. I have the correct jail but instead of dropping the IP (DROP) its just REJECT ing them in IPTABLES
This is my action:
action = iptables-multiport[chain="INPUT", name="default", port="ssh", protocol="tcp", action="DROP", returntype="RETURN", lockingopt="-w"]
Anyone can provide guidance on how I get the action to do this:
iptables -A INPUT -s [IP] -j DROP
It seems that REJECT is not harsh enough.
Thanks in advance,
"action = iptables-multiport[chain="INPUT", name="default", port="ssh", protocol="tcp", action="DROP", returntype="RETURN", lockingopt="-w"]"
Since you haven't posted the complete config for that jail, it's difficult to say what else might be wrong, but it's at least not action="DROP" but blocktype="DROP".
