Problem Upgrading from 11.0.9 to 11.5.29
mendip_discovery
[FIXED] Problem Upgrading from 11.0.9 to 11.5.29
Evening all
I have tried through both web based and ssh based upgrade options. I get the same error.
Code:
 MySQL databases are dumped to /var/lib/psa/dumps/mysql.preupgrade.11.0.9-11.5.29.20130615-220241.dump.gz
 Trying to upgrade APS controller database...
===> Cumulative APS controller database (apsc) upgrade has been started.
 Trying to backup MySQL database... done
 MySQL databases are dumped to /var/lib/psa/dumps/mysql.preupgrade.apsc.11.0.9-11.5.29.20130615-220243.dump.gz
ERROR 1548 (HY000) at line 67: Cannot load from mysql.proc. The table is probably corrupted
MySQL: 5.5.32 and I am running PHP: 5.4.16. On a CentOS system.
The apsc database is running as a InnoDB and I have tried a check etc on it and its fine.
Thanks in advance for any advice.€
Well that fixed it. Thanks.
What is strange is that I run this after I do any mysql updates.
Code:
mysqlcheck --all-databases --check-upgrade --auto-repair
