Problem viewing site by exclusive IP
Q
qcinet
Using Plesk 7.5.3 on RH 9.
I have added a new site using exclusive IP Address. I can view the site fine by domain name, but when I use the ip address, I get the default sw-soft page. I have tried a number of configuration options, but nothing is working.
Is this a bug or is there a simple trick to get this working?
In the control panel, you would click on Server, IP addresses, then under the Hosting column, click the '0' and select the new domain. Then click on 'Set as default'.
Thank you. This worked fine. I must have missed that before in the control panel.:)
