Problem with adding php command to chrooted shell
K
KarolB
Hello!
I used this way to add php to chrooted shell: http://kb.parallels.com/818
but i have some errors:
./recreate_chroot_env /usr/bin/php /usr/share/zoneinfo
Trying to install chrooted environment... ***** problem report *****
./recreate_chroot_env: line 61: : Nie ma takiego pliku ani katalogu
cleanup chrooted environments on existing domains
./recreate_chroot_env: line 64: : Nie ma takiego pliku ani katalogu
./recreate_chroot_env: line 67: : Nie ma takiego pliku ani katalogu
mknod: `/var/www/vhosts/chroot/dev/null': Plik istnieje
mknod: `/var/www/vhosts/chroot/dev/tty': Plik istnieje
/var/www/vhosts/chroot/bin ~
/usr/bin/php: application/x-symlink; charset=binary
probably it will not work in chrooted acconts
WARNING!
During the register /usr/bin/php in chrooted environment found some problems(see log file: /tmp/recreate_chroot_log)
Continue...
distribute chrooted environments on existing domains
done
/tmp/recreate_chroot_log is:
# cat /tmp/recreate_chroot_log
Trying to install chrooted environment... Value 'all' for option 'target' is not supported anymore
`/bin/bash' -> `bash'
`/lib/libncurses.so.5' -> `/var/www/vhosts/chroot/lib/libncurses.so.5'
`/lib/libdl.so.2' -> `/var/www/vhosts/chroot/lib/libdl.so.2'
`/lib/libc.so.6' -> `/var/www/vhosts/chroot/lib/libc.so.6'
`/bin/cat' -> `cat'
`/bin/cp' -> `cp'
`/lib/libselinux.so.1' -> `/var/www/vhosts/chroot/lib/libselinux.so.1'
`/lib/librt.so.1' -> `/var/www/vhosts/chroot/lib/librt.so.1'
`/lib/libacl.so.1' -> `/var/www/vhosts/chroot/lib/libacl.so.1'
`/lib/libattr.so.1' -> `/var/www/vhosts/chroot/lib/libattr.so.1'
`/lib/libpthread.so.0' -> `/var/www/vhosts/chroot/lib/libpthread.so.0'
`/bin/grep' -> `grep'
`/usr/bin/head' -> `head'
`/usr/bin/id' -> `id'
`/bin/ln' -> `ln'
`/bin/ls' -> `ls'
`/bin/mkdir' -> `mkdir'
`/bin/more' -> `more'
`/bin/mv' -> `mv'
`/bin/pwd' -> `pwd'
`/bin/rm' -> `rm'
`/bin/rmdir' -> `rmdir'
`/bin/sh' -> `sh'
`/usr/bin/tail' -> `tail'
`/usr/bin/touch' -> `touch'
`/usr/bin/du' -> `du'
`/usr/bin/vi' -> `vi'
`/bin/true' -> `true'
`/bin/false' -> `false'
`/usr/bin/scp' -> `scp'
`/usr/bin/groups' -> `groups'
/bin/cp: `/usr/bin/php' i `/usr/bin/php' to ten sam plik
WARNING!
Continue...
`/usr/lib/sftp-server' -> `/var/www/vhosts/chroot/usr/lib/sftp-server'
done
Whats wrong?
I'm a newbie but the kb article you pointed to does mention this below so if you happen to be doing this from 10.x then that may explain the error you get. If you have upgraded then perhaps the recreate_chroot_env script is picking up on the wrong environment. Just guessing.
For Parallels Plesk Panel versions 8.x and 9.x it is possible to use --target=all to cover all hosted domains at once.
