Hello Peter
Here is the result of you suggestion :
root@plesk:~# a2enmod authz_host authz_user
Considering dependency authz_core for authz_host:
Module authz_core already enabled
Enabling module authz_host.
Considering dependency authz_core for authz_user:
Enabling module authz_user.
To activate the new configuration, you need to run:
systemctl restart apache2
root@plesk:~# service apache2 restart
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xeu apache2.service" for details.
root@plesk:~# systemctl restart apache2
root@plesk:~# systemctl status apache2.service
× apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-05-28 09:12:44 CEST; 1min 11s ago
Docs:
Apache HTTP Server Version 2.4 Documentation - Apache HTTP Server Version 2.4
Process: 196944 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
CPU: 290ms
May 28 09:12:44 plesk.henkbartels.company systemd[1]: Starting The Apache HTTP Server...
May 28 09:12:44 plesk.henkbartels.company apachectl[196948]: AH00526: Syntax error on line 25 of /etc/apache2/plesk.conf.d/server.conf:
May 28 09:12:44 plesk.henkbartels.company apachectl[196948]: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
May 28 09:12:44 plesk.henkbartels.company apachectl[196944]: Action 'start' failed.
May 28 09:12:44 plesk.henkbartels.company apachectl[196944]: The Apache error log may have more information.
May 28 09:12:44 plesk.henkbartels.company systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
May 28 09:12:44 plesk.henkbartels.company systemd[1]: apache2.service: Failed with result 'exit-code'.
May 28 09:12:44 plesk.henkbartels.company systemd[1]: Failed to start The Apache HTTP Server.
root@plesk:~# journalctl -xeu apache2.service
░░ Defined-By: systemd
░░ Support:
Enterprise open source support | Ubuntu
░░ A start job for unit apache2.service has begun execution.
░░ The job identifier is 17264.
May 28 09:12:27 plesk.henkbartels.company apachectl[196938]: AH00526: Syntax error on line 25 of /etc/apache2/plesk.conf.d/server.conf:
May 28 09:12:27 plesk.henkbartels.company apachectl[196938]: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
May 28 09:12:27 plesk.henkbartels.company apachectl[196934]: Action 'start' failed.
May 28 09:12:27 plesk.henkbartels.company apachectl[196934]: The Apache error log may have more information.
May 28 09:12:27 plesk.henkbartels.company systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ Support:
░░ An ExecStart= process belonging to unit apache2.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
May 28 09:12:27 plesk.henkbartels.company systemd[1]: apache2.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ Support:
░░ The unit apache2.service has entered the 'failed' state with result 'exit-code'.
May 28 09:12:27 plesk.henkbartels.company systemd[1]: Failed to start The Apache HTTP Server.
░░ Subject: A start job for unit apache2.service has failed
░░ Support:
░░ A start job for unit apache2.service has finished with a failure.
░░ The job identifier is 17264 and the job result is failed.
░░ Subject: A start job for unit apache2.service has begun execution
░░ Support:
░░ The job identifier is 17379.
░░ Support:
░░ Support:
░░ Support:
░░ The job identifier is 17379 and the job result is failed.
lines 3097-3162/3162 (END)
Any other suggestions??
Henk
