Problem with Awstats and Perl.exe
javii
Hello,
We have some problems with Awstats and Plesk Windows, statistics are generated correctly but could not access the above statistics (November 2012, May 2012), due to an error with the file 404.2 xxxx.com/plesk-stat/webstat/AWStats/cgi-bin/awstats.pl
After a lot of testing, change the path to Perl on IIS, ISAPI and CGI Restrictions:
C:\Program Files (x86)\Parallels\Plesk\Additional\Perl\bin\perl.exe "%s" %s
For this:
C:\Program Files (x86)\Parallels\Plesk\Additional\Perl\bin\perl.exe %s
I solved the problem with the file xxxx.com/plesk-stat/webstat/AWStats/cgi-bin/awstats.pl, and is displayed correctly, but now not correctly generated statistics. Tonight were not generated.
I'd like to change the path of the previous Perl path, but since IIS does not allow it, it tells me that the path is invalid. How I can change it back? Is it possible to change this path from outside of IIS?
I add some screenshots...
