F
franky1973
Problem with Backup-Utility
hello, i have a big problem with the server-backups - i red several tipps but nothing works till now - please help
following error(s):
if i start to make a backup with plesk error-message: "Unable to create backup session: Empty error message from utility."
the server is an 1&1 server - therefor i moved the backup-directory to another place an putted a symlink to make it work
i checked the rights:
and the modules:
also i read the error_log file from psa
the system is writing data to the new dir but all backups dont work at all
i couldnt find any error but it still doesnt work - does anyone have a hint for me ?
following error(s):
# mv /var/lib/psa/dumps /srv/backup/psa/dumps
# rm -rf /var/lib/psa/dumps
# ln -s /srv/backup/psa/dumps /var/lib/psa/dumps
# ls -ld /srv/backup/psa/dumps
drwx------ 7 psaadm psaadm 49 2008-10-08 12:07 /srv/backup/psa/dumps
# ls -ld /srv/backup/psa/dumps/tmp
drwx------ 18 psaadm psaadm 4096 2008-10-08 12:37 /srv/backup/psa/dumps/tmp
and the modules:
# rpm -q psa-pylibplesk
psa-pylibplesk-8.6.0-suse10.2.build86080722.00
Processing config directory: /usr/local/psa/admin/conf/httpsd.*.include
[Wed Oct 8 12:19:23 2008] [notice] Apache configured -- resuming normal operations
[Wed Oct 8 12:19:23 2008] [notice] Accept mutex: sysvsem (Default: sysvsem)
Downloading the file products.inf3: 100% done.
Downloading the file plesk.inf3: 12%..21%..30%..42%..57%..60%..72%..81%..90%..100% done.
Downloading the file sitebuilder.inf3: 18%..21%..34%..40%..50%..62%..71%..80%..90%..100% done.
Downloading the file sso.inf3: 13%..26%..40%..67%..80%..93%..100% done.
Checking for installed packages...
Downloading the file PSA_8.6.0/plesk-8.6.0-suse10.2-x86_64.inf3: 10%..20%..30%..40%..50%..60%..75%..85%..93%..100% done.
Detecting installed product components.
Downloading the file plesk.inf3: 24%..30%..42%..51%..60%..72%..81%..93%..100% done.
Downloading the file sitebuilder.inf3: 15%..21%..30%..43%..52%..61%..70%..81%..90%..100% done.
Downloading the file sso.inf3: 13%..26%..40%..53%..67%..80%..93%..100% done.
Downloading the file PSA_8.6.0/plesk-8.6.0-suse10.2-x86_64.inf3: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% done.
rndc: connect failed: connection refused
Traceback (most recent call last):
File "/usr/local/psa/admin/sbin/agent_copy", line 6, in <module>
agent_copy.main()
File "/usr/local/psa/admin/share/agent_copy/agent_copy.py", line 44, in main
agentDir = os.path.join(agents_dir(), "PleskX")
File "/usr/local/psa/admin/share/agent_copy/agent_copy.py", line 8, in agents_dir
return os.path.join(plesk_config.get("PRODUCT_ROOT_D"), "PMM", "agents")
File "/usr/local/psa/admin/lib/python/plesk_config.py", line 19, in get
instance = PleskConfig()
File "/usr/local/psa/admin/lib/python/plesk_config.py", line 32, in __init__
self.__parse(configName)
File "/usr/local/psa/admin/lib/python/plesk_config.py", line 58, in __parse
raise ExInvalidConfigLine, line
plesk_config.ExInvalidConfigLine: Invalid config line: AWSTATS_BIN_D /srv/www/cgi-bin
agent_copy.main()
agent_copy.main()
