R
rayc@
I'm using very old CGI program. Complied. If you want, I can send the source.
Anyways, I treid search everywhere but it is not working.
User:Usergroup is fine.
Tried update suexec files but failed.
Error from /var/log/httpd/suexec.log is "directory is writable by others"
Error from /var/www/vhost/XXX/Stastics/logs/error.log is "Premature end of script headers: ttadmin.cgi"
Other info :
rpm -qf /usr/sbin/suexec -> httpd-2.2.3-43.el5.centos
stat /usr/sbin/suexec
File: `/usr/sbin/suexec'
Size: 23776 Blocks: 48 IO Block: 4096 regular file
Device: 9003h/36867d Inode: 1236409346 Links: 1
Access: (4510/-r-s--x---) Uid: ( 0/ root) Gid: ( 48/ apache)
Access: 2010-06-11 13:33:46.000000000 -0700
Modify: 2010-08-17 14:08:13.000000000 -0700
Change: 2010-08-17 14:08:13.000000000 -0700
Thank you
Other info :
Thank you
