Problem with Easy-Wi and Plesk
Dario_Nüssler
How do I remove psa-proftpd on my Server? or make config by proftpd-basic?
I have problems with Game Panel Easy-Wi
or is there a tutorial about this problem with Plesk and Easy-Wi?
sry for my bad English
What sort of problems with Game Panel Easy-Wi do you have? How this Game Panel Easy-Wi is related to Plesk? And how removing psa-proftpd can help with it? Could you please clarify a little bit?
Yes, that is Easy Wi can not edit the configs which means it does not have access because they are controlled via FTP. When I install proftpd everything goes with psa-proftpd can not edit the configs.
Easy-wi and Plesk are installed on a server and it does not work. I have tried it without Plesk and since everything went only with psa-proftpd is nothing more
Actually we do not recomend install any third-party software on Plesk server. Consequences may be unpredictable and you can do it only on your own risk.
Why not? There are the same configs as for original proftpd:
  • /etc/xinetd.d/ftp_psa
  • /etc/proftpd.conf
  • /etc/proftpd.include
Hey!
I have the same problem with easy-wi.
I run Plesk 12.0.18 and easy-wi with ProFTPD.
Some Games are work fine, Games like Minecraft not. :(
Have you solved the Problem?
What do you do?
@Dario_Nüssler: Du kannst mir auch auf deutsch schreiben :)
