Problem with greylisting.
sebas
Basic Pleskian
We have been having an increasing number of REJECTS for those using "Microsoft accounts".
Jan 8 08:00:55 www greylisting filter[21002]: Starting greylisting filter...
Jan 8 08:00:55 www greylisting filter[21002]: list type: black, from: ch1outboundpool.messaging.microsoft.com, match string: dsl|pool|broadband|hsd
Jan 8 08:00:55 www qmail-queue-handlers[21001]: handlers_stderr: REJECT
Jan 8 08:00:55 www qmail-queue-handlers[21001]: REJECT during call 'grey' handler
Then we added a rule:
/usr/local/psa/bin/grey_listing --update-server -domains-whitelist "add:*messaging.microsoft.com"
Now it is:
Jan 8 14:59:26 www qmail-queue-handlers[23006]: [email protected]
Jan 8 14:59:26 www greylisting filter[23013]: Starting greylisting filter...
Jan 8 14:59:26 www qmail-queue-handlers[23006]: handlers_stderr: DEFER
Jan 8 14:59:26 www qmail-queue-handlers[23006]: DEFER during call 'grey' handler
That moved the filtering from REJECT to DEFER. So we are trying to edit the dsl|pool|broadband|hsd rule.
So far we have been failing.
Code:
[root@www new]# /usr/local/psa/bin/grey_listing  -u -blacklist "del:dsl|pool|broadband|hsd"
unable parse pattern list: incorrect pattern "dsl|pool|broadband|hsd"
Code:
[root@www new]# /usr/local/psa/bin/grey_listing  -u -blacklist del:dsl|pool|broadband|hsd
-bash: pool: command not found
-bash: hsd: command not found
-bash: broadband: command not found
unable parse pattern list: incorrect pattern "dsl"
Code:
[root@www new]# /usr/local/psa/bin/grey_listing  -u -blacklist "del:dsl\|pool\|broadband\|hsd"
unable parse pattern list: incorrect pattern "dsl\|pool\|broadband\|hsd"
Code:
[root@www new]# /usr/local/psa/bin/grey_listing  -u -blacklist del:dsl\|pool\|broadband\|hsd
So far no luck.
Any ideas?
Thanks for your help.
What about using -domains-blacklist option instead -blacklist ?
~# /usr/local/psa/bin/grey_listing -u -domains-blacklist "del:dsl|pool|broadband|hsd"
SUCCESS: Update of server-wide settings complete.
