problem with mail enable --help please
V
vinhwsu
Hello all,
Please help me on how to fix the following problem:
There was an error sending your message: unable to connect to smtp server localhost:25
Thanks
the following reasons why its not working
1.Start the service for it?
2. Is the port open?
3. Is the same port being open for more than 1 program?
If number 2 answer is no u will need to open it.
If number 3 answer is yes u cannot use more than one program at the same port.
I know for sure, the port is open.
HOw can I check and see if more than one service use the same port?
HOw can I enable and disable from server? I know for sure the fire wall is open
in which way have you resolved?
i have the same issue.
Restart SMTP
Run
netstat -aon | findstr :25
1. you will see all processes that listen on port 25 (PID indicates the PID of application). Open Task Manager and find applications that have that PIDs
2. there must be 0.0.0.0:25 record, which indicates that mailserver is listening on all IPs, otherwise, 127.0.0.1:25 must be present instead.
If you see more than one PID, just stop that excessive application/service (usually, it's IIS SMTP),
In second case (if these records are absent), check IP binding in ME and dont forget to restart SMTP
At last, try
telnet localhost 25
ouch ... hope, here are all possibilities :)
check your anti-virus software...sometimes they have an build-in firewall !
