Problem with PHP cache, APC 64M to 128M or 256M
Tize
Basic Pleskian
Hello, last night I had some problems and I have read that to solve was recommended to update the cache 64M to 128M.
Now I have it again 64 M
I also read that someone else recommends expanding
Code:
apc.ttl=0
My question is that I do to avoid this error in the future please?
Last night I put 256M and this morning all failed again.
The problem comes from something with the APC.
Thank you very much.
Code:
nano /etc/php.d/apc.ini
Hello, suddenly the web do not work and add more memory to 256M but then again this morning error.
And not if the problem is that having changed from 64M to 256M or can happen.
Then I read that it is not advisable to have zero ttl. So I wanted to know if change ttl or leave zero to zero.
For everything to work well.
If I leave it as it had 64M or expand.
You've still NOT answered my question ...
What was the problem in detail or what was the error coming up when the web wasn't working, either in the LOGs or on the web page it self?
Sorry, you do not understand the expressions well.
The problem is that suddenly the web pages that work with databases had an error:
Code:
Warning: include(): Unable to allocate memory for pool. in /var/www/vhosts
Is there any way to see the errors that have arisen on the server to report it and can see it please?
