Resolved Problem with "Planned Task"
Hi YourShopPartner,
So this step is not working for me. What do i have to do now?
Yes, such warnings may appear and depend definetly on your current used operating system... but this should not be any problem at all for you, as you are aware, that the symlink links to the REAL executable:
(Create a symlink to your desired Plesk - PHP - version - executable ): ln -s /opt/plesk/php/7.0/bin/php /usr/bin/php
... so pls. feel free to replace my recommendation with a COPY command, so that CentOS/RHEL - based systems are satisfied as well. ;)
Thank you very much. Now i can run php in the chrooted account with php 7.
Really Amazing your detailed support and help!
Actually i have a Problem with the Shopware Console, not showing up with infos or commands, but i guess therefore i have to contact shopware directly.
But once more - GREAT Support, Thank you!
