• Dear Pleskians! The Plesk Forum will be undergoing scheduled maintenance on Monday, 7th of July, at 9:00 AM UTC. The expected maintenance window is 2 hours.
    Thank you in advance for your patience and understanding on the matter.
Problem with Plesk 8.4
qualispace
Regular Pleskian
Hello,
I am getting a problem with Plesk which is installed in a VE created by Virtuozzo. Whenever I click on any link in Plesk, I get the following error
Service is not available now, probably your Plesk is misconfigured.
Contact Your provider for details.
Internal Plesk error occurred: <b>Source:</b> Microsoft OLE DB Provider for SQL Server<br/><b>Description:</b> [DBNETLIB][ConnectionOpen (Invalid Instance()).]Invalid connection
I cannot even switch the DB provider for the Plesk nor can I run the Plesk Backup utility to take the backup and restore it in a fresh VPS. If I try to switch the DB, I again get the error Invalid Connection. It seems that the problem is with the DB which is currently used in Plesk. Can anybody let me know the solution to the problem?
