• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
Problem with SNI and Plesk 10.4 on Debian
B
buliwyf
Problem with SNI and Plesk 10.4 on Debian [Solved]
Hello,
i upgraded one of our Machines to Plesk 10.3 from 9.4 after that i upgraded Debian Lenny to Debian Squezze.
All went fine without problems.
Shortly after that i upgraded to Plesk 10.4.
We now try to setup SNI but it fails. For every Site the Default certificate is used.
This line in the apache logfile tells me, that SNI is enabled in the apache Webserver and working.
[Wed Nov 30 13:45:52 2011] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
It seems that Plesk does note recognize, that the Server is SNI capable.
Any ideas why?
Thanks for your help.
Not yet.
But after i changed it and restarted the psa service i was able to select a certificate in the
hosting settings for the Domain.
Now the website uses the correct certificate.
Thanks for your Help.
