• The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
Problem with subaccounts
AnonseT
Hello
I'm using the following commands to create a subdomain and import a FTP sub account from a csv file.
export PSA_PASSWORD="$(echo $line | cut -d ',' -f 2)"
echo "Done importing password: $PSA_PASSWORD"
/usr/local/psa/bin/ftpsubaccount --create $userName -domain server.edu -passwd '' -home /classes/$userName
According to the command-line guide, by setting the "PSA_PASSWORD" variable, I should be able to specify single quotes as the argument and it should work. The variables are populating correctly, as shown before the command is run. When the command runs, I get "Wrong syntax for command's '-passwd' parameter."
Any ideas?
