Problem with suexec
Make sure that you have correct permissions there. For example:
# rpm -qf /usr/sbin/suexec
httpd-2.2.3-31.el5.centos.2
# stat /usr/sbin/suexec
File: `/usr/sbin/suexec'
Size: 23776 Blocks: 48 IO Block: 4096 regular file
Device: 40h/64d Inode: 19078096 Links: 1
Access: (4510/-r-s--x---) Uid: ( 0/ root) Gid: ( 48/ apache)
everything seems correct:
httpd-2.2.3-31.el5.centos.4
Device: 901h/2305d Inode: 39693525 Links: 1
Access: (4510/-r-s--x---) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2010-05-06 13:01:46.000000000 +0200
Modify: 2010-05-07 04:57:43.000000000 +0200
Change: 2010-05-07 04:57:43.000000000 +0200
it's also strange that /var/log/httpd/suexec_log is empty since the Plesk upgrade. Is there a way to disable this suexec?
But there is difference in permissions - you have root:root but in my sample - root:apache.
