Problem with update from 10.0.0 to 10.0.1
J
Jeff (YaBB World)
Hi
I cannot update from Plesk 10.0.0 to 10.0.1
I got this Error.
Installation started in background
skip package 'plesk-skins-10.8.0-10092415.all' from component base - there is same or newer version of this package is installed (in system plesk-skins-10.8.0-10092415.all)
skip package 'drweb-base-5.0.1-090811.11.all' from component drweb - there is same or newer version of this package is installed (in system drweb-base-5.0.1-090811.11.all)
skip package 'drweb-bases-5.0.1-0.all' from component drweb - there is same or newer version of this package is installed (in system drweb-bases-5.0.1-0.all)
skip package 'drweb-common-5.0.1-0plesk.all' from component drweb - there is same or newer version of this package is installed (in system drweb-common-5.0.1-0plesk.all)
skip package 'drweb-daemon-5.0.1-0plesk.all' from component drweb - there is same or newer version of this package is installed (in system drweb-daemon-5.0.1-0plesk.all)
skip package 'drweb-updater-5.0.1-0plesk.all' from component drweb - there is same or newer version of this package is installed (in system drweb-updater-5.0.1-0plesk.all)
Auflösung der Paketabhängigkeiten wird geprüft.
E: Broken packages
---X--- `apt-get` output ---------------------
Reading package lists...
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
plesk-mail-pc-driver: Conflicts: psa-mail-driver
psa-mail-pc-driver: Conflicts: psa-mail-driver
---------------------- `apt-get` output ---X---
Collecting error details into log file...
Sources list:
Installed in system packages:
Error: Installation will not continue
Es wurden nicht alle Pakete installiert.
Bitte kontaktieren Sie den technischen Produktsupport.
