Problem with update to 11.5.30
Juanin4
Hi.
I'm trying to update my plesk, from 11.0.9 to 11.5.30 but auto-installer throws the following error:
An internal error occured in auto-installer, rev.324981 AiComponent.cpp, line 335.
¿Any ideas?
Just clicked on the link that shows on my plesk front page.
And the plesk itself was installed by my ISP (ovh) when i purchased the server.
Now it gives me a warning
Parallels Panel pre-upgrade check...
WARNING: There are domains registered in Panel which URL does not have the http:// prefix. Such domains will not be shown on the Domains page. Check http://kb.parallels.com/en/113359 for more details.
i have to investigate before upgrading, but it seems it will work.
Thank you!
Well. Just try to use autoinstaller now.
I have exactly the same error. I'm trying to upgrade Plesk 9.5.4 on a centos 5.x (64-bits) server to the latest Plesk 11.5.30 and it results in the following:
ERROR: An internal error occured in auto-installer, rev.324981 AiComponent.cpp, line 335.
I receive this error on 5 different servers. I tried to upgrade with the latest plesk-installer as well as the following installers:
parallels_installer_v3.12.0_build120601.16_os_CentOS_5_x86_64
parallels_installer_v3.7.1_build101103.18_os_CentOS_5_x86_64.
When I select to upgrade to plesk 11.0.9, the auto-installer does not give this error and I'm able to upgrade to 11.0.9, but I prefer to upgrade to the latest version, 11.5.30.
