Resolved Problem with wordpress toolkit
fd_paz
Basic Pleskian
I did upgrade to the WordPress Toolkit version to 2.3.0, but after upgrade when I click on the Wordpress link in the left sidebar of the Plesk Panel, I receive "Error: Can not Find Domain by id 68" error.
My Plesk is: OS ‪CentOS 6.9 (Final)‬, Product Plesk Onyx, Version 17.0.17 Update #32
Would anyone help me solve this problem?
If I remove it from "Extensions Management" and reinstall it, will the problem be resolved?
Thanks
Hi fprm67,
first of all, I strongly recommend to upgrade to the ( current ) latest, stable Plesk version 17.5.3 .
Afterwards, pls. keep in mind, that Plesk comes with the "Plesk Repair Utility" ( => Plesk Repair Utility ), which is able to investigate issues/errors/problems and this utility can even repair these found issues/errors/problems automatically. ;)
If you don't try it, you will never know if this could solve your issue. As you can't "destroy" something by removing and adding a Plesk component / extension, why don't you give it try and report back?
Hello fprm67,
Could you please make sure that domain with ID 67 is presented in Plesk DB? Run:
plesk db "select id, name from domains where id = '67'"
Could you please clarify, which Plesk interface do you use: service provider view or power user view? Is there an anility to go to the list of WordPress instanses? By the link from right menu, for example?
Thank you all.
I have removed "Addendio - WordPress Plugins and Themes 1.3.0" extension and everything is back to work.
I tried to upgrade to version 17.5.3 from the Plesk Panel, but the upgrade failed. Since it is a "porduction" server, I'm afraid of destroyin something because I'm not very experienced in codes and Linux.
Using "Plesk Repair Utility" is Safe? Could it destroyi something?
Thank you
Hi fprm67,
