fliegerhermi
Regular Pleskian
after one of the latest update I get the following errors:
1) When clicking on extensions I get:
2) When accessing advanced monitoring it shows grafana is stopped. When trying to start it I get:
Any idea how to fix this?
500 Error
Class 'Zend_Uri' not found
Execution extension has failed with exit code 1, stdout: ERROR: Error: Class 'Zend_Uri' not found (Client.php:312) , stderr: PHP Warning: include(): Failed opening '/opt/psa/admin/plib/vendor/composer/../plesk/zf1/library/Zend/Uri.php' for inclusion (include_path='/opt/psa/admin/plib/vendor/plesk/zf1/library:/opt/psa/admin/plib'); File: /opt/psa/admin/plib/vendor/composer/ClassLoader.php, Line: 444 PHP Warning: include(): Failed opening '/opt/psa/admin/plib/vendor/composer/../plesk/zf1/library/Zend/Uri.php' for inclusion (include_path='/opt/psa/admin/plib/vendor/plesk/zf1/library:/opt/psa/admin/plib') in /opt/psa/admin/plib/vendor/composer/ClassLoader.php on line 444 [2021-10-08 15:30:57.294] 7331:6160481147869 ERR [panel] Class 'Zend_Uri' not found: 0: /opt/psa/admin/plib/vendor/plesk/zf1/library/Zend/Http/Client.php:312 Zend_Http_Client->setUri(string 'http://127.0.0.1:3030/api/') 1: /opt/psa/admin/plib/vendor/plesk/zf1/library/Zend/Http/Client.php:290 Zend_Http_Client->__construct(string 'http://127.0.0.1:3030/api/') 2: /opt/psa/admin/plib/modules/grafana/library/Http/HttpClient.php:29 PleskExt\Grafana\Http\HttpClient->__construct(string 'http://127.0.0.1:3030/api', string '') 3: /opt/psa/admin/plib/modules/grafana/library/GrafanaService/GrafanaServiceApiClient.php:30 PleskExt\Grafana\GrafanaService\GrafanaServiceApiClient->getHttpClient(string '', boolean false) 4: /opt/psa/admin/plib/modules/grafana/library/GrafanaService/GrafanaServiceApiClient.php:39 PleskExt\Grafana\GrafanaService\GrafanaServiceApiClient->isApiAvailable() 5: /opt/psa/admin/plib/modules/grafana/library/GrafanaService/GrafanaServiceBroker.php:636 PleskExt\Grafana\GrafanaService\GrafanaServiceBroker->waitForTheGrafanaStartup() 6: /opt/psa/admin/plib/modules/grafana/hooks/ApiCli.php:140 Modules_Grafana_ApiCli->grafanaRestartCommand() 7: /opt/psa/admin/plib/Extension/Hook/ApiCli.php:26 Plesk\Extension\Hook\ApiCli::call(string 'grafana', array) 8: /opt/psa/admin/plib/api-common/cuModule.php:419 cuModule->_callCommand(string 'grafana', array) 9: /opt/psa/admin/plib/api-common/cuApp.php:79 cuApp->_callCommandMethod(array) 10: /opt/psa/admin/plib/api-common/cuModule.php:172 cuModule->_callCommandMethod(array) 11: /opt/psa/admin/plib/api-common/cuApp.php:73 cuApp->_executeCommand() 12: /opt/psa/admin/plib/api-common/cuApp.php:53 cuApp->runFromCliGate() 13: /opt/psa/admin/plib/api-common/CuExecutor.php:69 CuExecutor->execUtil(string 'cuModule', string 'runFromCliGate') 14: /opt/psa/admin/plib/api-common/CuExecutor.php:131 CuExecutor->run() 15: /opt/psa/admin/plib/api-cli/CliUtilityRunner.php:25 CliUtilityRunner->run() 16: /opt/psa/admin/plib/api-cli/CliUtilityRunner.php:34 require_once(string '/opt/psa/admin/plib/api-cli/CliUtilityRunner.php') 17: /opt/psa/admin/plib/api-cli/extension.php:3
